Side exit exhaust
Old Apr 19, 2006 | 01:20 PM
ridemyjansen's Avatar
ridemyjansen
Default Side exit exhaust
Hey all, just wondering if anybody has tried putting a side exit exhaust on their Z? Would there be any benefits in having a side exit?
Old Apr 19, 2006 | 01:27 PM
Cannysage's Avatar
Cannysage
side exhaust would have more bends, therefore won't be good for power gains - that would be my opinion.
Old Apr 19, 2006 | 01:31 PM
plumpzz's Avatar
plumpzz
side exit exhausts usually don't have mufflers. Since its shorter, the exhaust velocity would help the exhaust exit the system faster.
Old Apr 19, 2006 | 01:38 PM
Anything is possible but...
you may have problems with local laws. Generally any exhaust that exits behind the rear wheels is OK. I would hate to get a repair and inspect ticket for improper exhaust.
Old Apr 19, 2006 | 01:42 PM
Cannysage's Avatar
Cannysage
+1 it's bad enough that cops harass people with loud exhaust.. bad idea to give them one more reason to pull you over.
Old Apr 19, 2006 | 09:25 PM
Rickdogg's Avatar
Rickdogg
Out of hiatus
I know someone is working on a full race exhaust for the Z that is going to dump pretty early underneath the car. That will be loud!!!
Old Apr 19, 2006 | 09:46 PM
Vick781's Avatar
Vick781
i seen it done on a roush mustang
Old Apr 20, 2006 | 01:20 AM
showstoppertk's Avatar
showstoppertk
it would definately create clearance (bottoming out) problems and you'll likely end up cracking your side skirts unless you cut out an opening in the side skirt. I don't think it would look good on a Z.
Old Apr 20, 2006 | 08:28 AM
overZealous1's Avatar
overZealous1
i have thought about trying this on my own car. very hard to get a muffler under there though, but want to do a cut out somewhere and use a super long 1-1.5" high tip. will take alot of work to build the tip though and look good. here is a pic of a nascar exhaust. pretty wicked how they make the transition from tube to oval. i have seen a couple premade kits that may be able to be modified to work though from other manufacturers.
Old Apr 20, 2006 | 08:51 AM
Quamen's Avatar
Quamen
The one above might not work though since it would more than likely be right near the gas tank which could cause problems. Would have to exit either near the middle of the door or right up front.
Old Apr 23, 2006 | 10:02 PM
plumpzz's Avatar
plumpzz
Usually the side exit exhausts exit right underneath the front doors. It could be done as long as the car isn't less than 4-5 inches above the ground... Oval tips makes it easier to fit.
Old Apr 24, 2006 | 04:29 AM
davidf's Avatar
davidf
The new SLR exhaust exits right in front of the drivers door which looks pretty sweet.
Old Apr 24, 2006 | 08:23 AM
overZealous1
ya, the pic was mostly to show what they did with the tips to create ground clearance. it is really hard to get the exhaust to come out anywhere inbetween the front and rear tires. so either right after the front tire or right before the rear tire is about the only way to keep decent ground clearance, but tips similar to the ones pictured would have to be made. would look pretty sick, but would almost need to be custom for every single different car. super tight to get mufflers under the center of the car compared to just the rear.
Old Apr 24, 2006 | 08:26 AM
overZealous1
just had an idea, maybe right behind the rear tire. a hole would have to be cut, but there would be space to do it there. have a nice polished alum. or ss ring to protect the rear bumper plastic, but it may look pretty cool having a 3.5" tip flush with the body poking out there.
sales@czp
Sep 23, 2019 03:30 PM
Stevo Z
Oct 3, 2015 09:14 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
