MREV V2 Independent Dyno Tested on Bone Stock 287HP Motor (Wired 24/7's 05 Touring)
Old May 24, 2006 | 04:11 PM
  #181
Act of God's Avatar
Act of God
I just finished mine, my neighbor helped me out big time. I think it took about an hour to do. I just installed the MREV V2, none of the other jibber jabber.
As for the drive after, I'm think I feel a little somethin...I need more test time though, I only took it out for like 2 minutes and a few backroad pulls.
Should I reset the ECU or will it figure it out itself?
Old May 24, 2006 | 05:22 PM
  #182
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Don't worry about resetting, I didn't and I'm still running strong.
Do as many WOT / redline runs as possible to bump the ECU into the performance map, that's as good or better than what a reset will do anyway.
If anyone is interested, earlier in this thread I mentioned getting about 8 gallons of 100 octane which resulted in a tank of ~95+ octane. Well that was frickin' awesome and I was pulling like crazy, but I was not about to spend $80 per tank of gas just to commute to and from work/school. So I put 91 octane back into the car on the next tank.
It felt like I was in limp mode. It was absolutely insane power loss, according to the butt dyno. 2nd gear on a flat surface had no power. I stepped on the gas and it didn't go anywhere, it felt like I was in 6th.
Then, several WOT/redline runs over the course of a couple of days, and the power came back. Just yesterday, I drove me (200lbs) and my friend (250lbs) on the freeway and third gear was pulling better than ever. Which is surprising because before the power came back, just me in the car felt like **** in 3rd gear.
I'm glad the power came back, but I'm also looking forward to my tune with the Greddy Emanage ultimate and the new kinetix hfc.
Old May 24, 2006 | 05:28 PM
  #183
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
I reset mine.. by just disconnecting the batteries for the duration of the install.. as soon as i disconnected it, i drained the battery by holding the brake pedal for a bit.. i did a few redline runs right after i got it out of the garage.. i felt a bit of torque gain.. and i noticed that the popcharger got slightly louder also.
Old May 24, 2006 | 08:09 PM
  #184
Zincognito's Avatar
Zincognito
i need to hurry and do mine. im just waiting on the crank pulley and hyperforce. i might as well order isothermal....
Old May 28, 2006 | 10:40 AM
  #185
RNL323's Avatar
RNL323
Mod My Ride
Bosssho....
Thinking about going with the crawford plenum with my MREV 2. I've held off installing my MREV2 because I wanted to get other opinions with this set up. Your posts have been helpful... I have a unichip so I would get a tune soon after my install if I decide to go this route BUT what did you mean you said,
Originally Posted by bosssho
...and with the Crawford Plenum that I had to retap a hole for in the back so I would say a straight MREV V2 install should be under 2 hrs easy.
re-tap a hole?
post or hit me with a PM
Old May 29, 2006 | 06:34 AM
  #186
Earl's Avatar
Earl
Uh.... the parts where I bolded seem wrong.. For manual transmissions, you're supposed to dyno them on 5th gear. For auto tranny, 4th gear is the correct gear to dyno in.
Why is 4th gear the correct "gear" to dyno the A/T in? The auto tranny has a torque converter so it's never has a constant gear ratio. Now if you can fiqure out how to lock the converter then it's a different story. The A/T 350Zs and G35s I've seen dyno all made more power in 3rd gear than in 4th.
Old May 29, 2006 | 12:44 PM
  #187
3hree5ive0ero
Retired Admin
I'm no expert in this area, but I've always been told that on our Zs and Gs, in order to dyno in a 1:1 gear ratio, you would dyno it in 5th for manuals and 4th gear for autos.
Old Jun 1, 2006 | 06:02 AM
  #188
godmans's Avatar
godmans
I believe I am way too lean that the ecu is pulling timing...
To make it worse, there was a Jetta (02~03) VR6 that was
right on my *** that I could not pull away from....
guess I should get a tune soon or simply take away my spacer.
FYI: I currently have 5/16" spacer + MREV2
Any advices? I believe I wouldn't be going for a tune so soon
I hear you guys. Well, LMG_35C you are in NJ, so you are actually a lot closer to Maryland and Altered Atmosphere than I am so I would go that route if I were you. They have the same software that Technosquare has, but you can drive there, get the tune, dyno your car, and get it reflashed...I am thinking of doing that...but it costs like $1000 for the whole thing...BUT...there is no down time or taking your ECU out and shipping it to CA. They also tune to 93 Octane b/c we are on the East Coast. amG35, being in FL you are probably not driving to Maryland, but it wouldn't kill ya...it may be worth it to ya. It all depends on how into your car you are and what you are using it for ya know.
On my old G35 Sedan I had the Technosquare reflash for a stock exhaust, crawford V5, and then everything else was the same...My car dynoed an avg of 235/235 RWHP/RWTQ on my old Sedan...but that was after all the mods were on which included an URUD crank pulley too.
I like you guys, was not too happy, after ordering the MREV V2 to read about lean low rpms...especially with the Crawford Plenum being on my car already...but, if you want to play you have to pay right. So we have two things going for all three of us...we are on the east coast with 93 Octane, and if you save up you can get a tune that should augment the whole package. The key recommendation is to not install both the Crawford and MREV V2 or MREV V2 and either ME Spacer unless you have all your mods on and are ready to tune.
Old Jun 1, 2006 | 08:02 AM
  #189
3hree5ive0ero
Retired Admin
i highly doubt that jetta vr6 was stock.. even if your ecu was pulling timing, it should still be faster than a jetta right?
Old Jun 1, 2006 | 10:07 AM
  #190
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
If you dont want to get tuned, maybe you're better off with no spacer and just run the MREV2. We know it makes like 13hp by itself.
Old Jun 1, 2006 | 10:09 AM
  #191
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
UPDATE
I will be getting kinetix HFC on the car soon and getting a tune with the Greddy emanage ultimate.
Stay tuned for results. ETA 3 weeks. I'm busy as a ****.
This will be interesting, everyone can see what kind of HP you can make with stock intake and stock exhaust.
Old Jun 1, 2006 | 11:45 AM
  #192
godmans's Avatar
godmans
Thank you for the reply Bro, I really feel like I should get a tune or do sth.. ( I felt that my car bog sometimes after the Mrev2 + 5/16" but not all the time tho). Yet, after this morning...driving to work as usual and getting tailgated by that jetta without being able to pull an inch from him, I know that I should remove the spacer by now and put it back on when I can afford the money and more importantly the time to get a dyno shop and a good tuner to do some tuning
Btw, is there any piggyback or whatever that can allow a newbie to tune the A/F ratio on the dyno? I dun feel like I can find a good tuner in Toronto (unless if I have a good holiday week that I can spend in the states lol)
Thanks again everyone
Old Jun 1, 2006 | 12:34 PM
  #193
amG35's Avatar
amG35
Originally Posted by Wired 24/7
UPDATE
Wired, I too am interested in getting tuned with either the UTEC or eManange. If you would be so kind, what were the reasons for you choosing the eManage? Thanks.
Old Jun 1, 2006 | 02:13 PM
  #194
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Well I didn't want the eManage blue because of the problems burning out coil packs that I read about. I would rather not have to stockpile coils ready for replacement all the time. So I went with the eManage Ultimate.
I wanted to get tuned at the same place I got my dyno (for this thread), and I mentioned UTEC to the guy and he said UTEC is more of a pain in the *** than one would think.
I don't really need all the advanced functions that UTEC has. Plus, I got a good deal on a used EU from the marketplace section... 750 including complete harness and pre-wired autosport harness. It was wired correctly (I checked) so that saved me a ton of time.
Plus, I think the EU should be pretty self-tuneable if I get the AAM cipher tool and datalog stuff like air/fuel ratio, injector pulse, timing etc. I wanted to be able to do some self-fine-tuning easily, so EU was a good choice since it is windows XP and laptop friendly.
**Disclaimer** Do not take my word for any of what is written below, you should do independent research and verify what you can and should do (and more importantly, what you should NOT do) with a tuner. I am not a tuner and don't pretend to be one.
Here's what you can do (I think) -
Get the EU, get an aftermarket wideband sensor, and get a bung welded at the junction in your y-pipe. Then plug it into the EU and make ABSOLUTELY sure it is working properly with little margin for error. If you have a 2004.5 or newer, you can check the AFR of the aftermarket wideband versus the stock widebands using the AAM cipher tool.
If the aftermarket wideband is working okay, use the EU to do feedback-based target-air/fuel tuning. I do not know what AFR you should use as the target, maybe 13 up to 5000rpm and 12.5 to redline (DO NOT QUOTE ME ON THIS). Once it finds its target map, turn the feedback tuning feature off and simply use the map it generates. The cool thing about this is if you get new mods, you can just turn the feedback on again and it will re-adjust the air-fuel ratio to be spot on.
The reason you don't want to use feedback tuning ALL the time is that if for some reason your wideband stops working properly, your car could blow up from receiving bad data. Let's say you're running lean but your wideband reads that you are running perfect. The EU will not adjust to the lean condition and you will be at risk for detonation...
Now for the more economical version:
Since widebands and welding and junk is expensive, you can just get the AAM cipher tool. It is $400 which is about the price of a good wideband anyway. If you have a 2004.5 or newer, you can use a look-up table that translates wideband voltage to AFR (posted in a cipher thread in the Engine Drivetrain Forced Induction forum). Datalog the AFR and use the data to little by little adjust the pulse widths on the injectors using the EU. I wouldn't get too crazy with adjusting timing though, because the EU still can't set overall (final) timing, only offset (plus or minus) from stock ECU timing.
Hope this helps.
Old Jun 1, 2006 | 03:53 PM
  #195
godmans's Avatar
godmans
OMG, thanks wired, this is some very detailed feedbacks =) I appreciate it, at the meantime I would be looking for a good dyno shop / hardwares to tune my fuel mixture this few months.. Moreover, I believe I will take my 5/16 spacer off tonite to see if it will make a difference in any sense
Old Jun 1, 2006 | 06:19 PM
  #196
dovla's Avatar
dovla
godmans, what is your AFR? How do you know your ECU is pulling timing? At what RPM? Thanks
I have advanced 2% timing again and on 93 octane see no retards, or any different than before MREV-V2 was added to ½” spacer.
Old Jun 1, 2006 | 08:25 PM
  #197
bosssho's Avatar
bosssho
Yeah, that was quite the response from wired huh. He is into that self tuning thing like a madman and God love him for it.
If you are like me and don't have that desire to go ***** out with the self tuning spend the $600 and get a Technosquare or AAM tune based on your mods, and you won't have to take anything out of your car except your glove box and ECU to ship it in and be done...if it's a money thing for now, just take the spacer off and call it a day like Wired said with the MREV V2 for now until money is right for a tune.
If you want to go into it and fine tune the $hit out of everything, or if you plan on a lot more mods, do what Wired said and get the self tuning means b/c your ends will keep changing and it will be a good investment.
For me I am done...the pulley is going on next week and that's it...If I don't hit the 13s at my track I will just keep gutting the $&$&$ car until I get my power to weight ratio down to where I can do it that way.
Old Jun 2, 2006 | 09:56 AM
  #198
LMG_35C's Avatar
LMG_35C
http://forums2.freshalloy.com/showthread.php?t=150103
FYI - AAM is running a GB on their reflash over on the Fresh Alloy Forums under both 350Z and G35..
Old Jul 15, 2006 | 08:01 PM
  #199
masterj26's Avatar
masterj26
wired any update on the dyno with emanage ultimate and HFC?
Old Jul 16, 2006 | 01:35 PM
  #200
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Not yet... I need to find a chunk of free time
