MREV V2 Independent Dyno Tested on Bone Stock 287HP Motor (Wired 24/7's 05 Touring)
Old May 21, 2006 | 12:28 PM
  #161
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
Originally Posted by bosssho
Went to AAM in MD with my 05 5AT Coupe. As a comparison to base, I looked up some old G35 Driver Dyno results and what I found was that a 6MT Coupe would dyno in the neigborhood of 229+/- RWHP & 222+/- RWTQ and a 5AT Coupe would put down 227+/- RWHP & 216+/- RWTQ.
With my 05 and its Mods, Grounding Wires, Stillen/K&N/JWT CAI, ME MREV V2 with Isothermal gasket and TB Bypass Copper Coolant plate, Crawford V5 Upper Plenum, and a Stillen Cat back Exhaust and 2900 miles on the odemeter my car pulled 241.12 RWHP & a pathetic 215.61 RWTQ and was pushing 14.23 for an AF ratio b/t 5K RPMS and redline...the initial RPM AF ratio was low too, like Wired 24/7's Z.
After the dyno ran tunes were done, the AF ratio was made perfect and was running in the low to high 13s. The car put down 246.45 RWHP and a better, but still not what I wanted, 224.9 RWTQ. From what I am told the huge torque gains are simply attributed to the car not running so lean.
So let me stop and pause here to say I need to do a lot more testing and tuning b/c I need to see where I am losing torque. If you reread what I said the stock coupes are laying down for torque I am barely above that and not even equaling my old Sedans 229 RWTQ numbers and the exhaust was bone stock on that car which was also a 5AT. So I am going to mess around with the stock upper plenum and the MREV V2 and then maybe just the Crawford V5 and the stock lower collector...either way I need to be seeing around 240 at the wheels for torque...even if I sacrifice a hair of peak RWHP.
AAM was the first shop I have ever been to where I was not allowed to drive my car. While I understand them being safe, it doesn't give me 100% control of how the car is being driven on the dyno so you always have that what if factor going on in your mind...at least I do. This is not a negative against them in any way, but just for me, IMHO, not the way I like to dyno. Also of note is that AAM only ran my car up to an apparent 6300 RPMS or so which did not accurately show where my power dropped off b/c at this RPM the HP was still climbing or at least staying even. I know my snowmobiles make peak power from say 7200-8100 RPMS and then lose like 30% power so I wanted to see where my car did the same. So....
Yesterday, when I had 5 free seconds I drove up to NH and went to my buddy's Mustang Shop where he has the exact same dyno set up as AAM does. A Dyno Jet, using SAE corrections and a smoothing factor of 5. I did two back to back runs in 3rd gear which is what I am told AAM did, and both runs were nearly identical at 249.71 and 249.66 RWHP with torque coming in at 228.17 and 228.42...not equaling my old Sedan yet, but damn close. Also...my Sedan was run in 4th gear b/c that's what we were told to run the cars in way back then...so to do an apples to apples I did one more run in 4th gear and the RWHP dropped down to 242.74, but the RWTQ jumped up to 231.31 besting my old Sedan finally. It was 2 degrees cooler yesterday than on Thursday in MD, and it was 34% humid vs. only 20% humid in MD.
In conclusion, the tune was well worth it for several reasons, but I need to find out where I am losing roughly 10 lbs/ft of RWTQ.
I hope this helps some of you out there.
Uh.... the parts where I bolded seem wrong.. For manual transmissions, you're supposed to dyno them on 5th gear. For auto tranny, 4th gear is the correct gear to dyno in.
Old May 21, 2006 | 01:00 PM
  #162
bosssho's Avatar
bosssho
Originally Posted by amG35
bosssho, thanks for the info. Did you install some type of ECU management like UTEC or eManage? If not, how did AAM tune your G and get the AFR down in the low 13s? Thanks again.
Just like Technosquare out in CA, they plug into your ECU and just remap it...The fuel is just added as needed to adjust the car's AF ratio from too lean to the good range.
Old May 21, 2006 | 01:02 PM
  #163
bosssho's Avatar
bosssho
No offense, but nope and nope. 4th and 3rd my friend. 1:1 ratio for the 6 speeds and pretty much 1:1 for the 5ATs in 3rd. Early on the thought was that the autos should be in 4th, but not any more.
Old May 21, 2006 | 04:35 PM
  #164
3hree5ive0ero
Retired Admin
Hm.. so you're saying that manuals dyno in 4th gear and autos dyno in 3rd? Never heard that. Maybe we could get a third party chime in? No offense to you as well and none taken. Just trying to clarify things, not argue.
Old May 21, 2006 | 04:46 PM
  #165
ssgohan434's Avatar
ssgohan434
You dyno in whatever gear that has a ratio of 1:1 for you, which is usually 4th for 6speeds as he said and 3rd for AT transmissions.
Old May 21, 2006 | 05:07 PM
  #166
bosssho's Avatar
bosssho
Isn't sad we have to prefice everything with sorries and no offenses. That's the internet sometimes though right.
I took no offense. I knew you were just trying to get to the bottom of it, which I think we have w/ssgohan434's chime in. Take it easy.
Old May 21, 2006 | 05:54 PM
  #167
OCG35Coupe's Avatar
OCG35Coupe
M/T..................A/T
1st 3.794.........3.540
2nd 2.324.........2.264
3rd 1.624.........1.472
4th 1.271.........1.000
5th 1.000.........0.834
6th 0.794...........N/A
Old May 21, 2006 | 06:07 PM
  #168
bosssho's Avatar
bosssho
well then...I am offically lost as to why I was told what I was told. :-0
Old May 21, 2006 | 07:25 PM
  #169
3hree5ive0ero
Retired Admin
That's what I thought it was.. for our specific cars, 5th gear in MT and 4th gear in AT was the 1:1 ratio thus the correct gear to dyno in..
bossho - try and see if there's a difference in your hp/tq in 5th gear and tell us the update. and yes, it is said that we have to add such sidenotes to avoid unintended e-fights.. oh well
Old May 21, 2006 | 07:51 PM
  #170
Mr_pharmD's Avatar
Mr_pharmD
4th might be 1:1 in AT but most of the time everyone will dyno it in 3rd.
Old May 21, 2006 | 08:45 PM
  #171
azzaz's Avatar
azzaz
ok, i read through this thread starting from page1, i currently have an ssv manifold on although would like to put the mrev version2 lower plenum on with the 5/16" spacer. i have a utec so i can tune it.
i still have my stock lower collector, am i able to send this to motordyne and get it modified to an mrev v2??? im in Aus so this could be difficult. or will the mrev v2 be available to purchase on the motordyne web site soon enough, to avoid sending mine in???
thanks Aaron
Old May 21, 2006 | 09:22 PM
  #172
3hree5ive0ero
Retired Admin
uh.. thas not exactly how it works..
You order the MREV2 from MotorDyneEngineering.. they send you one, and if you have the 287hp engine and you would like a core refund, you send in your original lower collector to get part of your money back.. Go to motordyneengineering.com for more info or PM tony (Hydrazine)
Old May 22, 2006 | 04:21 AM
  #173
azzaz's Avatar
azzaz
ah cool i guess ill have to wait untill the mrev v2 is back in stock then
Old May 22, 2006 | 04:58 AM
  #174
mchong75's Avatar
mchong75
Tony,
I need to know/authorization from you if I can get a Dyno credit if I provided you with my Dynco results.
Current mod: Popcharger & Nismo exhaust - 1st Dyno run
Update mod: MREV2 - 2nd Dyno run
Update mod: 5/16" spacer - 3rd Dyno run
Old May 22, 2006 | 08:15 AM
  #175
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
Cool. That works.
One more dyno sequence would make a good data set. Get the electronic dyno data if you can.
I'll be back June 3. We can work out the details then.
Tony
Old May 22, 2006 | 10:02 AM
  #176
mchong75's Avatar
mchong75
Thanks Tony
Anyone in N Dallas who purchased the MREV2 get it installed yet? If so, where? & how much?
Jotech quoted me $150 for 5/16" spacer & MREV2 installation (at one time), but if you do individual installation for Dyno purpose...they charge $150 for each part installed. Ouch!
Old May 22, 2006 | 10:19 AM
  #177
3hree5ive0ero
Retired Admin
I got the MREV2 installed.. it's been 3 days.. i did the installation myself so i didn't have to pay anybody..
if i were you, i'd just do the istallation myself.. it's not that bad.. quite easy.. just time consuming i'd say
Old May 22, 2006 | 10:48 AM
  #178
mchong75's Avatar
mchong75
How long did it take you?
No tools or am I mechanically inclined to take stuff apart. LOL
Where in TX are you?
Old May 22, 2006 | 04:43 PM
  #179
3hree5ive0ero
Retired Admin
It took me about 2.5 hours to do.. but that's because I was cleaning the plenums during my installation time.. you're going to need some tools.. i had to go buy a torque wrench and a 4mm socket.. it cost me a pretty penny too.. I live in North Dallas area
Old May 23, 2006 | 07:13 AM
  #180
bosssho's Avatar
bosssho
I just went back into my Dyno folder and from 2004 on the G35Driver Forum there was a huge dyno shoot out with a bunch of Nissan/Infinitis...all but one 350Z/G35/300ZX/Maixima dynoed in 3rd if they were a 4AT or 5AT and in 4th if they were a 6MT...except one 350Z 6MT that dynoed in 5th. For what it's worth.
Again, 4th gear saw my Max HP go down about 7RWHP, but my RWTQ went up 3 clicks.
To the guys on the fence on installing an MREVV2...it's not bad...my install was about 3 hrs, broken up over an hr at a time b/c I was doing other things...and I did the isothermal gasket and TB by pass valve too...and with the Crawford Plenum that I had to retap a hole for in the back so I would say a straight MREV V2 install should be under 2 hrs easy.
