Aps Test Pipe Install Time
Old May 17, 2006 | 12:11 PM
Z350MAN04's Avatar
Z350MAN04
Default Aps Test Pipe Install Time
Does anyone know how long it takes REAL TIME to do an install with the APS test pipes? thanks
Old May 17, 2006 | 12:49 PM
sja177's Avatar
sja177
It took me about 2 hours the very first time. After that it takes me about 30 mins or so.
Old May 17, 2006 | 12:53 PM
Z350MAN04's Avatar
Z350MAN04
thank you, do you do it on ramps or do you have access to a lift?
Old May 17, 2006 | 04:03 PM
With a lift - one hour.
Spray hardware and oxygen sensors with penetration fluid. Let it set for 20 minutes.
Remove the oxygen sensor from the catelitic converter after the catalytic converter is off the car.
Old May 17, 2006 | 04:18 PM
outdoorsmen438's Avatar
outdoorsmen438
Default test pipes
What is penetration fluid?
Old May 17, 2006 | 04:19 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Some stuff called "liquid wrench" for example, I've heard WD-40 works too.
Old May 17, 2006 | 06:23 PM
Thumbs up
Old May 17, 2006 | 06:30 PM
Z350MAN04's Avatar
Z350MAN04
thanks, for comments and well . . pics too.. haa
Old May 17, 2006 | 06:36 PM
LOL. I think the advertisement is 20 years old. I have a can of Liquid Wrench. Hell it might be 20 years old also.
Old May 18, 2006 | 07:55 AM
Blurr350z's Avatar
Blurr350z
Yeah the can I used was from when my dad worked on his cars (1970s). The stuff still worked though
Old May 18, 2006 | 07:58 AM
Z350MAN04's Avatar
Z350MAN04
ok . . . so . . is this something you really recommend? spray a liquid wrench type stuff on the nuts. i was not sure if that was serious, but i guess it is a must huh? sorry this is the first mod i am making to my z. i also have the kinetix ssv intake coming too. turbo soon to follow.
Old May 18, 2006 | 08:13 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Exhaust components reach fairly high temperatures. These high temperatures tend to provide the necessary activation energy to drive oxidation (corrosion) reactions on your nuts and bolts, so sometimes they have trouble coming free.
Salt from ocean air is also a catalyst to oxidation reactions as you might already know...
bottom line is liquid wrench is a handy tool but you might not need it.
Old May 18, 2006 | 08:18 AM
Z350MAN04's Avatar
Z350MAN04
i guess it all makes sense. i had not really thought to much about it. are all of you from the tampa area?
Old May 18, 2006 | 08:25 AM
plumpzz's Avatar
plumpzz
wtf are u talking about. liquid wrench is a water displacer. Itll REMOVE water. It also lubricates to help you remove the bolt out easier. Its best to lubricate something when you torque it on to get proper torqueing.
If you use galvanized bolts (ones that come w/ the test pipe), u'll be fine. USE WD40 or something of teh sort, as it makes the job much much much easier.
Old May 18, 2006 | 08:31 AM
Yes I am serious. I would never advise anything I have not used, or anything that might be harmful. WD40 is a excellent lubricant, but will not dissolve corrosion as well as Liquid Wrench.
Old May 18, 2006 | 08:35 AM
Z350MAN04's Avatar
Z350MAN04
ok, well i am new to this particular forum. i am in tampa racing forums, but i figured i would come to the 350z forum to find out nitty gritty details. like i was sayin, this is my first mod to this car. i have done stuff a long long time ago to older muscle cars but never a late model tuners car. thanks for everybodies input.
JjL
East Canada
Jun 12, 2019 03:04 AM
z33z_nutz
Sep 23, 2015 07:22 PM
Tylerx7z33
Sep 21, 2015 01:43 PM
_koubie_
Sep 20, 2015 06:34 PM
FromGtoZ
Sep 20, 2015 03:41 PM
