UPDATE!! larger MAF installed only...
Old Sep 6, 2006 | 01:09 PM
  #61
chadalac350z's Avatar
chadalac350z
i am having the weirdest problem i installed a ram air intake and the car did not like this very much it was fine thru all gears except for idle which was rough for about 2 mins then it would just die,please help me i am forced to put factory back on at this time any info on this would help out with all the people installing cai u would think there would not be a problem please email me at cjudkins@cfl.rr.com i put the factory hoses back on and the just had the cone filter but it ran worse. help....
Old Sep 6, 2006 | 01:15 PM
  #62
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Try resetting the ECU by disconnecting the negative battery terminal, and pumping the brakes a few times after that.
Reconnect it and see if you still have the same problem.
If that doesn't work, you might try leaving the battery terminal disconnected overnight at least 12+ hours.
