Ram air into Popcharger?
Old Aug 3, 2006 | 05:38 AM
zodiac's Avatar
zodiac
Default Ram air into Popcharger?
I'm thinking about running a ram air pipe/tube from my grille up to the front of my popcharger.
Has anyone done this...or seen this? I am hoping that it will help the air temp coming into the intake. Anyone know if this will even help? My next step after that is to "conceal" it with a black or silver mesh grille insert.
Any opinions on this?
Old Aug 3, 2006 | 05:43 AM
savvy's Avatar
savvy
you will basically have a k&N Typhoon when you are done. They still get the same almost nothing powergains
Old Aug 3, 2006 | 05:56 AM
Yes. If you can think of it, it has been done. One of our members used ducting for a clothes dryer. It isn’t pretty, but gets the job done.
Old Aug 3, 2006 | 06:13 AM
iceburns288's Avatar
iceburns288
Don't mind the guys obsessed with dyno numbers- a ram air intake won't show gains on a dyno, of course. The whole point of ram air is to shove air into the intake while the car is moving, and on a dyno the car isn't moving, so no air is 'rammed' into the engine. When you're moving, it is. Ram air intakes will provide a real-world performance gain, unfortunately it's unprovable (unless you put a dyno in a wind tunnel).
Old Aug 3, 2006 | 08:37 AM
zodiac's Avatar
zodiac
I appreciate the info guys. My thoughts are that the air temp inside the engine bay is higher than the outside ambient temp (Especially when we are breaking 100 deg Fnht every damn day for the last month), and that it will improve performance and possibly help keep the engine cooler. I have found some plastic flex tube (guttering) that is black and more resiliant than the "dryer hose". If I get time this weekend, I'll try it out.
Thanks again.
Zod
Old Aug 3, 2006 | 05:37 PM
gtmule's Avatar
gtmule
Thanks again.
Zod
In theory (and usually practice) engines will be more efficient with warmer intake air, and make more power with colder intake air. So (esp in winter) you might see power gains when you get on it, but a slight MPG loss when you're not, so be warned.
Old Aug 3, 2006 | 05:39 PM
saberphx's Avatar
saberphx
Make sure to post pictures.
Old Aug 3, 2006 | 05:58 PM
taurran's Avatar
taurran
It won't do you much good. If you really are interested in doing something of this nature on the popcharger, get an air duct cutout for the front bumper.
Old Aug 3, 2006 | 06:02 PM
edwin350z's Avatar
edwin350z
i have a typhoon and i think it works well..
Old Aug 3, 2006 | 06:28 PM
lunartick13's Avatar
lunartick13
Go to zcarparts.com and look up this item (airdam) #112960. This is what you are looking for I have it and it was easy to install but i had to remove the right side of the inner grill (you can hardly notice it`s gone) price on the air dam was like 90.00 plus shiping..
Old Aug 3, 2006 | 08:14 PM
doskiez's Avatar
doskiez
I just recently did this on my Z i felt a difference on the interstate at 60 to 70 when accelerating to pass but around town its just the same as it was. To help with concealment try using a ready made intake *scoop* i guess youd call it used for brake cooling ducts they are black plastic and easily zip tied to the front grille they are not noticible at all. I used silicone brake duct hose left over from my race car its sturdy heat resistant and fits very nicely into the front of the popcharger. Duct is kind of expensive but the scoop was only 16 bucks
Good luck
Old Aug 4, 2006 | 06:15 AM
ct350z's Avatar
ct350z
i just purchased the varis air duct kit. going to put on some type of hose inbetween and see how it goes. i'll keep you informed!!!! maye some pic's!!!
Old Aug 4, 2006 | 12:09 PM
Gralark's Avatar
Gralark
They do make cold air intake ducts. Check out this link. It will do exactly what ur saying u want to accomplish. And it will look good and connect right up to the air inlet.
I just ordered one.
http://www.thezstore.com/page/TZS/PROD/PFFC22/11-2960
Old Nov 13, 2006 | 09:26 AM
ZLadie2000's Avatar
ZLadie2000
notice any difference in acceleration with the varis air duct kit?
Old Nov 13, 2006 | 10:10 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Even though this is an old thread, I'll respond...
Nismo v2 front bumper does it for you I believe
Old Nov 13, 2006 | 10:56 AM
ZLadie2000's Avatar
ZLadie2000
I looked up the bumper, didnt see it. may just cut a hole in my bumper...
Old Nov 13, 2006 | 11:23 AM
mikewagon's Avatar
mikewagon
pep boys has some ducts you could buy chrome or black, cheap, and will probably work. but for the jwt i dont think it will matter cause its not only sucking in air from just the front, its all around.
Old Nov 13, 2006 | 12:27 PM
ZLadie2000's Avatar
ZLadie2000
I noticed a difference in acceleration when I popped my hood and drove at up to highway speeds, car just has more cool air. i tried this at the track and they wouldnt let me do it lol
Old Nov 13, 2006 | 01:14 PM
z-u-later's Avatar
z-u-later
WTF!? You're nuts!
Old Nov 13, 2006 | 01:57 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Bad..... very bad idea
