5/16 Plenum Spacer
Old Aug 14, 2006 | 11:33 AM
Tay350z's Avatar
Tay350z
Default 5/16 Plenum Spacer
Does the plenum spacer change the sound of the car at all? And can it be installed by someone with minimal experience....? (I installed my popcharger myself) Thanks
Old Aug 14, 2006 | 11:40 AM
There are a dozen spacer install threads in the intake forum. Search. You are no longer a newbie.
Old Aug 14, 2006 | 12:24 PM
djnc's Avatar
djnc
i get this loud sucking sound from my 5/16...sounds kinda cool...most people say it makes the exhaust note lower, but i didn't get that with mine
Old Aug 14, 2006 | 03:18 PM
Hella's Avatar
Hella
i noiticed no difference in sound at all.
Old Aug 14, 2006 | 05:50 PM
dTor's Avatar
dTor
Yes, you will get a little more growly sound under the hood, especially at WOT.
Yes, you can install it with minimal mechanical experience.
GET AN IN/LB TORQUE WRENCH!!!!
Old Aug 15, 2006 | 06:48 AM
Andy@Performance's Avatar
Andy@Performance
Performance Nissan
There is a very faint difference in sound, you definitely have to look for it but to the average person you wont be able to hear a thing. Great mod BTW.
https://www.mynismo.com/products/?id=2737
Old Aug 15, 2006 | 09:20 AM
cvt's Avatar
cvt
+1
Old Aug 15, 2006 | 09:34 AM
z-u-later's Avatar
z-u-later
. . . but if you stick the Motordyne sticker on your windshield, you'll hear a nasty growl coming from your VQ when you're at WOT.
Old Aug 16, 2006 | 09:17 PM
MarkRacerX's Avatar
MarkRacerX
Default Impressions
So as far as gains goes?? Is this tops for bang for buck mod?
Looking for next hp mod, so far just Nismo intake...
Old Aug 17, 2006 | 04:45 AM
z-u-later's Avatar
z-u-later
Plenum spacer should be your next mod . . .
Old Aug 17, 2006 | 05:12 AM
JNL's Avatar
JNL
installing the spacer is easy, motordyne has excellent instuctions. I finsihed installing mine last night in the dark. Every couple of minutes I had to walk over to my neighbors house to trip the motion sensor on his porch light.
If you have a rev-up engine you will need the Mrev2 lower collector to take advantage of the gains.
For me, I noticed a huge difference in sound, especially @ WOT around 5500-6000rpms, but I also installed a z-tube and popcharger at the same time, so its hard to say how much the spacer alone changed the sound. I've only been able to drive it for a couple of miles so far, but I definately noticed more power, and the power seemed like it was a lot more consistant all the way till redline. I'm hoping that it will get even better after the ECU has time to adjust.
Old Aug 17, 2006 | 09:33 AM
z-u-later's Avatar
z-u-later
Where did you get the Z-tube? I want to replace my OEM tube.
Old Aug 17, 2006 | 11:25 AM
JNL's Avatar
JNL
www.mynismo.com has a pretty good price for the z-tube/ popcharger combo
$189
Old Aug 17, 2006 | 01:26 PM
StarcraftBW's Avatar
StarcraftBW
very little
Old Aug 17, 2006 | 02:12 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
The change in sound is nothing you won't get used to in about 1-2 days. Nothing like changing exhaust parts.
_koubie_
Sep 20, 2015 06:34 PM
