Need help w/ Mrev2 Installation
Old Aug 16, 2006 | 04:06 PM
JNL's Avatar
JNL
Question Need help w/ Mrev2 Installation
The Mrev2 lower collector came with a gasket sitting on it, but the spacer has gaskets on both sides. Do I need the gasket on the lower collector? I wouldn't think so but I want to make sure.
Old Aug 16, 2006 | 05:06 PM
mikead_99's Avatar
mikead_99
No you don't, in fact stacking gaskets is a bad idea.
edit: ahh, after reading post below I see you aren't talking about a third clamshell gasket.
Old Aug 16, 2006 | 06:48 PM
JNL's Avatar
JNL
nevermind, I realized that yes I do need it.
Old Aug 16, 2006 | 07:18 PM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
We supply a "Manifold" gasket to seal the interface between the lower plenum (MREV2) and the lower manifold. Use this to replace the stock metal "Manifold" gasket.
Then there is your stock metal "Plenum" gasket. You reuse this gasket so you can keep a seal on the oil galleries. Its all illustrated in the installation manual.
Let me know if you have any questions.
Tony
Old Aug 17, 2006 | 04:28 AM
JNL's Avatar
JNL
Where is the coolant line that you install the coolant control valve on? Is it attached to the upper plenum near the windshield side?
Old Aug 17, 2006 | 04:42 AM
z-u-later's Avatar
z-u-later
It's on the driver's side just below the air intake tube.
Old Aug 17, 2006 | 05:28 AM
JNL's Avatar
JNL
its attached to the upper plenum right, towards the back of the engine and not visible unless you stick your head right near it? When I installed the MREV2 and spacer I unplugged a tube and it looked like a little coolant came out, thats the one, right?
Old Aug 17, 2006 | 09:07 AM
Hydrazine's Avatar
Hydrazine
Thats it!
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
