Motordyne MREV2 & 5/16 PLENUM SPACER
Old Dec 20, 2006 | 11:18 PM
  #101
usmanasif's Avatar
usmanasif
Must say that this has been a great thread indeed. I am now sold on the MREV2 minus 5/16" spacer. ***cough**forum discount?**cough***
Old Dec 21, 2006 | 06:00 AM
  #102
ZLadie2000's Avatar
ZLadie2000
Originally Posted by Hydrazine
The dyno data attached is from two different 2004 350Z's and G35 Sedans.
The overlaid plots are all on the same dyno, same dyno day.
Can you say with certainty which if from the Z and which is from the Sedan?
I assure you the only difference here is the daily mood of the respective ECU's.
Dont read beyond this point without first looking at the plots and making a decision
PS - the plot on the top is the Sedan. The only reason they have even a slight difference is the ECU temperment. They could just as easily switch roles the very next day.
Hmm, thanks for posting the plots... What affects ECU temperament?
Old Dec 21, 2006 | 09:52 AM
  #103
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
That's the MILLION DOLLAR question.
There are many, many, many different input variables the ECU monitors.
Old Dec 21, 2006 | 10:13 AM
  #104
RBlover69's Avatar
RBlover69
yea. really we would probably need a day to go thorugh the amount of correction and variables lmao. Especially since the ecu in the the Z has been tuned so highly already from the factory. ....Hopefully when im done with my na mods ima get a utec and hopefully reach the mythical 300rwhp mark in my revup.
Old Dec 22, 2006 | 03:47 AM
  #105
jeff91ta's Avatar
jeff91ta
Intensepower.com was having a GB for the MREV2 + 5/16 ISO back it October which I passed on.... but then they had another GB for the same two items about 1 month ago. This time I jumped in and I now have the MREV2 and 5/16 ISO sitting in my basement. Unfortunately the car is in storage and I would like to do some before and after runs in the car during the spring. I'm hoping to satisfy the butt dyno this way.
Check with Darren at Intensepower.com to see if this GB is still happening.
Old Dec 22, 2006 | 06:15 AM
  #106
Hydrazine's Avatar
Hydrazine
We are having the same sale price on our website now. Also check with our other participating dealers.
Old Dec 24, 2006 | 10:43 AM
  #107
platinum350's Avatar
platinum350
I just installed my spacer and want to know if you guys that have JUST installed the spacer noticed a big difference?
Unfortunately I can't drive the Z until my left rotor arrives. I started it and rev'ed it, sounded slightly different as the RPM's came down close to idle.
Old Dec 24, 2006 | 11:05 AM
  #108
My butt dyno is terrible. Lets say that the spacer adds 6 peak horsepower. No way can I feel a 2 percent change in power.
Old Dec 24, 2006 | 11:36 AM
  #109
ZLadie2000's Avatar
ZLadie2000
I noticed a difference when I installed the spacer on my non rev up, more top end hp, more torque. About 10 hp more. Felt great! Sounded great too!!
Old Dec 26, 2006 | 01:18 PM
  #110
platinum350
good!
Old Feb 8, 2007 | 09:31 PM
  #111
VtotheZ's Avatar
VtotheZ
I love this thread, I think I just spend an hour reading the WHOLE thing. I was gunna ask all these newb questions but thanks to this forum, and TONY I am fully informed and now know what I would like to do with my 03 350z. Thanks again guys!
Old Feb 11, 2007 | 05:54 AM
  #112
2Cool4Skool's Avatar
2Cool4Skool
Default crank pulleys
Originally Posted by q8z
one more thing i have been reading bout the UNORTHODOX crank pulley..... interesting if it increases HP without drawbacks to the Z, is the UNORTHODOX recommended or not.
It works because the crank pulley is lighter than the OEM one. There's less energy wasted turning the heavy OEM pulley so more power is available to the rear wheels. It works for sure.
The problem I have with these crank pulleys is they don't have a rubber/plastic damper like the OEM one. They're a solid piece of aluminum. Long-term durability of the crankshaft & bearings may be sacrificed because of lack of damper.
I thought about getting a light crank pulley off of Ebay cuz this one company makes one with a damper built in, but I wasn't familiar with the name of the company (their rep that is) so I didn't get it.
Old Feb 17, 2007 | 06:57 AM
  #113
xav_350z's Avatar
xav_350z
i installed the spacer and didn t notice any diff :S
Old Feb 17, 2007 | 09:17 AM
  #114
lbz's Avatar
lbz
I installed the mrev and 5/16 spacer about a month ago and love it. Noticeable difference. Still waiting on my core refund for my stock lower collector though...
Plan is to add stillen dual exhaust and then ECU reflash.
Old Feb 17, 2007 | 09:40 AM
  #115
black06z's Avatar
black06z
Thanks for the info. Im sold on the MREV2 only. Until Im ready to get a tune, I'll add on the spacer later.
Old Feb 17, 2007 | 04:55 PM
  #116
MyFairladyZ2006's Avatar
MyFairladyZ2006
I'm installing the Motordyne 5/16" spacer this week.
Will I need an ECU reflash now with all my other mods?
Old Feb 18, 2007 | 04:07 AM
  #117
ncparamedic's Avatar
ncparamedic
Prodigal Son
I dont think this question was ever answered...
What is the difference between the Isothermal & Isothermal copper??
Thanks guys..
**did i over read the answer and miss it??**
Old Feb 18, 2007 | 08:27 PM
  #118
igetgreens's Avatar
igetgreens
not if you are planning on modding your car more
Old Feb 20, 2007 | 07:40 AM
  #119
Hydrazine's Avatar
Hydrazine
Thanks guys..
Its not answered in this thread but it has been in many others.
The Copper can be used in hot or cold climates, and is highly recommended for cold climates. In very cold climates, not only there is more benefit from it in the way of temperature reduction of the plenum, there are no valves to mess around with. ...But it costs a little more.
If you live in a place like Ca., Fl. or Tx. you rarely encounter cold temperatures anyways, so you can use the regular Iso Thermal and save a few bucks.
Either kit can be used in either climate.
The copper is easier with a set and forget installation, and has more potential but it costs more.
The regular Iso Thermal is a lower cost alternative.
Old Feb 20, 2007 | 01:09 PM
  #120
TENGAI's Avatar
TENGAI
MREV2 + APS Tallboy FTW
