Car idles close to 1k after JWT Popcharger install.
Old Sep 21, 2006 | 05:49 PM
Diesel350's Avatar
Diesel350
Default Car idles close to 1k after JWT Popcharger install.
Is this normal?
Old Sep 21, 2006 | 06:08 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
try resetting your ECU, disconnect negative battery terminal overnight and pump the brakes a few times before you connect it.
Old Sep 21, 2006 | 06:20 PM
sry110's Avatar
sry110
Mine idles closer to 500 RPM after JWT install. It is a steady idle which is probably a good sign. I disconnected the battery for a half hour or so while I did the install, but I did not pump the brakes.
Old Sep 21, 2006 | 06:31 PM
Diesel350's Avatar
Diesel350
What does pumping the brakes do? Any specific number of times I should pump the brakes?
Old Sep 21, 2006 | 09:05 PM
Armitage's Avatar
Armitage
Mine idles where it did before the install.
Diesel - Are you in teh Z Club of Florida? Good friend of mine lives down there, she has a 350z with Volk rims, bolt-ons, etc. Maybe you know her.
Old Sep 21, 2006 | 09:20 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
It's just to make sure any remaining voltage or whatever gets drained. If the ECU is only disconnected for a few minutes up to a couple of hours, it does not reset because it can store a charge for that period of time.
I think hitting the brakes helps drain the capacitors...that's all
Old Sep 21, 2006 | 09:21 PM
taurran's Avatar
taurran
A 1k idle should make for smoother operation and easier starts. I'd thank the mod faeries.
Old Sep 22, 2006 | 03:55 AM
Diesel350's Avatar
Diesel350
Yes I'm part of the Z club of Florida. Does she have chromed GT-7's?
Old Sep 22, 2006 | 10:28 AM
Armitage's Avatar
Armitage
Yeah, the black chrome or whatever its called. Next time you see her, tell her Scott said hello.
Old Sep 23, 2006 | 12:59 PM
theanswer0127's Avatar
theanswer0127
mine idles same rpm as before install... around 800
Old Sep 24, 2006 | 11:05 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Did you reset the ecu yet?
Old Sep 24, 2006 | 12:22 PM
Diesel350's Avatar
Diesel350
Yes still idles the same but to me it seems the car does pull harder after the reset. Before it felt really sluggish.
Old Sep 24, 2006 | 12:58 PM
Armitage's Avatar
Armitage
Even when the car is fully warm it idles at 1k?
Old Sep 24, 2006 | 02:08 PM
Diesel350's Avatar
Diesel350
Yeah usually between 800 and 1k. It flucuates when I'm at a light.
Old Sep 24, 2006 | 09:46 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
With air conditioning on, it idles higher. With AC off it should be about 650 if no one changed it...
Old Sep 25, 2006 | 08:03 PM
J-BoneZ's Avatar
J-BoneZ
Not trying to jack the thread but I'm in need of help. I just got done installing mine and now have a broken bolt where you mount the bracket to hold the popcharger still, so now the only way i can get it out is by drilling the bolt out. But was I supposed you use the factory air box bolt or a different one? Because in the instructions it looks like they use a completely different bolt.
Thanks
James1990
Dec 16, 2015 08:57 PM
ThreeFiveZero Z
Sep 12, 2015 04:33 PM
