Safe to run K&N filter unoiled?
Old Oct 3, 2006 | 05:55 PM
350drft's Avatar
350drft
Default Safe to run K&N filter unoiled?
Cleaned my filter, wondering if I can run it without oil, in order to get some better airflow. Is this safe? Element looks pretty good at filtering, even without oil.
Old Oct 3, 2006 | 06:00 PM
edwin350z's Avatar
edwin350z
pretty sure its safe. not sure if you will get better airflow though.
Old Oct 3, 2006 | 06:08 PM
350Zenophile's Avatar
350Zenophile
I recall the K&N literature being pretty explicit about not doing that.
Old Oct 3, 2006 | 06:24 PM
Eazzy's Avatar
Eazzy
NOOOOOOOOOOOOOOOOO !!!!!!! Dude ---The oil is what makes the K@N filter---FILTER --------With out the oil u could suck a Sparrow thru it!!!! NOOOO Way positively,absolutly, completely
Old Oct 3, 2006 | 06:25 PM
Eazzy's Avatar
Eazzy
Hell --U mite just as well throw it away
Eazzy's Avatar
Eazzy
And throw sand in ur intake !!!!
Old Oct 3, 2006 | 06:39 PM
350drft's Avatar
350drft
What differentiates this filter from dry filters then?
Old Oct 3, 2006 | 06:52 PM
Eazzy's Avatar
Eazzy
A dry filter uses a finely woven paper element that is good at filtering but restrictive as soon as it starts getting dirty and eventially clogs. The K@N is made with a Cotton Fiber that is far less finely woven and nonrestrictive. To compensate for that, u use the oil which sprays wet but drys sticky.
The Cotton Fiber is like a skeleton that holds what does the filtering. The Oil.
Old Oct 3, 2006 | 06:57 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
if you want better airflow, run no intake - you might gain 1 hp if the stars align correctly
the K&N is a wet type filter - it relies on the oil to be effective
Old Oct 3, 2006 | 07:12 PM
Eazzy's Avatar
Eazzy
Simple and to the point---Heed it.
Old Oct 3, 2006 | 10:24 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
The oil ATTRACTS dirt and particles, the fibers do not generally STOP dirt and particles unless they are able to attract it.
Old Oct 4, 2006 | 10:15 AM
_Donovan_'s Avatar
_Donovan_
I bought the car with the K&N already on it, what oil are you talking about.
Old Oct 4, 2006 | 12:48 PM
Eazzy's Avatar
Eazzy
go to any place that sells KN and they will have the KN oil in a spray----People may bust on me for this but I clean mine by running it thru the dishwasher, then letting it air dry in the sun.
Old Oct 4, 2006 | 02:07 PM
tkrienke's Avatar
tkrienke
A K&N filter, as stated above, needs oil to function properly. It occasionally needs to be cleaned (depends on your driving conditions) by rinsing it thouroughly and allowing it to dry, then re-oiling it. EDIT: as mentioned above, any large auto parts store (Advance, NAPA, etc) sells the reoil kit. Hope that helps.
Old Oct 4, 2006 | 02:27 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
It comes with oil on it. As mentioned, if you need to clean it (and you do, every few months) you should get the filter recharge kit which includes a spray on oil and possibly a cleaning solution.
Be sure not to over-oil it
Old Oct 4, 2006 | 02:33 PM
Alberto's Avatar
Alberto
Cranky FI Owner
+1 on not over oiling it. Can make car run funny/shut off or throw a CEL if you get too much oil on the MAF/IAT.
Old Oct 5, 2006 | 07:39 AM
Zquicksilver's Avatar
Zquicksilver
I don't think that's necessary, ... instead of letting it dry in the sun, why don't you just use JETDRY?
Kidding aside, I'm sure others use this technique... I just take the hose (set to light spray) and wash it inside-out. I then set it on newspaper for some good old sun baking. I just mist it with the oil, enough to cover it thoroughly. It will get on your MAF sensor if you saturate it
Zquicksilver
Old Oct 5, 2006 | 07:49 AM
Z1 Performance
Former Sponsor
yep - I personally use the K&N cleaner, let it sit for a few minutes, then run it under the faucet here at the shop. Once the filter is clean from debris (as the water rinses through it you'll see it get clearer, meaning it's clean). From there, I let it air dry for an hour or so, then you gently mist the oil from the recharge kit onto the filter, till it's just pink. Let the filter stand up and down for a few minutes so any excess runs off, wipe the base, reinstall, done
Old Oct 5, 2006 | 11:11 AM
05-Z's Avatar
05-Z
Or you can buy a new filter.
Old Oct 5, 2006 | 11:38 AM
jtabraham's Avatar
jtabraham
Try installing one of those Oreck Air Purifiers right on to your plenum...then you won't need your K&N
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
