Bonus check came, looking for new intake solutions. Help please.
Old Oct 4, 2006 | 10:11 AM
_Donovan_'s Avatar
_Donovan_
Default Bonus check came, looking for new intake solutions. Help please.
I have a 03 Z, 3 months ago nissan installed a new engine. I am not sure if it is Revup or Non.
I am looking for what combination of Mrev2 spacer and plenum would be the best gains for me. I already searched and found nothing but arguements between people and facts and crap basically. I know that I will need to get a new strut bar so that is not a problem. Will the mrev2 with a huge spacer and a new plenum be good for me or does the spacer make it that i will not need to get a plenum?
Also, I will SC it later this year, so will thiese mods work still or should i go with the kinetix ssv now. Plus, if I do get the intake done, should I retune. What gains am I looking at with a retune?
Old Oct 4, 2006 | 10:35 AM
Biochem7's Avatar
Biochem7
Regular
Just get the MREV2, similar gains to the 5/16 spacer and no need to worry about hood clearance.
Old Oct 4, 2006 | 10:39 AM
_Donovan_'s Avatar
_Donovan_
But I am looking for the whole package. I plan on getting as much as I need. will i get more gains with a larger plenum also or larger spacer. What would a maxed out intake be.
Old Oct 4, 2006 | 10:53 AM
_Donovan_'s Avatar
_Donovan_
If I just go ahead and get the Mrev2 and the crawford plenum. That would be great, right? but for the spacer, what size would be the best for those two mods?
Old Oct 4, 2006 | 11:09 AM
Biochem7's Avatar
Biochem7
Regular
Search, there have been some dynos showing no significant gains adding a spacer to the MREV2 for the non-revup engines. I don't know about the Crawford plenum + MREV2 but are you willing to spend another $300 plus the cost of a new strut bar?
Old Oct 4, 2006 | 11:43 AM
_Donovan_'s Avatar
_Donovan_
yes I am
Old Oct 4, 2006 | 11:45 AM
Before wasting your money on an aftermarket upper plenum, check the Sport Z Magazine Plenum vs Spacer Shoot-Out.
Old Oct 4, 2006 | 11:51 AM
Alberto's Avatar
Alberto
Cranky FI Owner
For the standard motor-a spacer/Crawford Plenum is more than enough. Save $200-250 and dont do the MREV....
Old Oct 4, 2006 | 11:52 AM
Alberto's Avatar
Alberto
Cranky FI Owner
This is physically impossible. MREV 2 is a slightly mod'd lower plenum like what yuo have, AND a 5/16" spacer. That woudlnt work WITH a Crawford Plenum, its spacer + mod'd lower plenum, or you do a new upper Plenum (Crawford)....
Old Oct 4, 2006 | 11:54 AM
Vq.turbo.DremZ's Avatar
Vq.turbo.DremZ
From what i piece together you want to run both the crawford plenum AND a 5-16th spacer? Just run the Mrev2 and the spacer/or crawford. Assuming that the crawford plenum is about the same volume as the 1/2in spacer, You'll see more topend gains, whereas the 5/16th spacer will yeild more area under the curve. Thats all good unless you have the revup.
Old Oct 4, 2006 | 12:04 PM
_Donovan_'s Avatar
_Donovan_
So, mrev2 and crawford is all I need. They fit together and eliminates the spacer?
Old Oct 4, 2006 | 12:22 PM
mikead_99's Avatar
mikead_99
Yup.
Old Oct 5, 2006 | 04:42 AM
Alberto's Avatar
Alberto
Cranky FI Owner
No can you people not read?! Crawford plenum WILL NOT WORK with any spacer. You choose one or the other. In the case of a non revup motor like you have-Id choose the Crawford-if you dont mind losing/replacing the STB. If you want the stock bar do the 5/16" spacer.
If you have a Revup-do the MREV 2.
Old Oct 5, 2006 | 05:14 AM
Gumpdriver's Avatar
Gumpdriver
Just get a normal plenum spacer. Not MREV
Old Oct 5, 2006 | 03:37 PM
undrgnd's Avatar
undrgnd
That is exactly correct. If you look around you will see many have done just that. I got the APS plenum and MREV2. They work great together. I got Tony's opinion on the combination beforehand, and it seemed to be a toss-up, Crawford or APS. These plenums are the equivalent of a stock plenum + spacer.
Old Oct 5, 2006 | 05:35 PM
titanjc's Avatar
titanjc
Where is the sticky for these spacer / MREV2 threads???
Old Oct 7, 2006 | 07:36 AM
Alberto's Avatar
Alberto
Cranky FI Owner
You are incorrect. MRV2 is a machined lower plenum AND a 5/16" spacer. Sounds like to me you just have the machined lower plenum and run an APS upper plenun with it. That is not a full MRV 2 kit....
Old Oct 22, 2006 | 03:07 PM
DanielW's Avatar
DanielW
the mrev 2 and spacer are two seperate items. You can buy the mrev 2 lower collector seperately from the spacer on motordynes website.
apex locator
Jul 23, 2021 02:27 AM
Sleeper_Z
Sep 30, 2015 10:25 AM
