Mrev2 + Spacer = Omg
Old Nov 30, 2006 | 09:07 AM
PPW Z33's Avatar
PPW Z33
Originally Posted by Hydrazine
Yes, for the 287 engine it is, but depending on where your A/F ratio is starting from, it may or may not run lean.
So it is best to know what your A/F ratio is before starting. If your A/F is at or below 13 its good to go. Otherwise the best results can be made with a tune to increase the fuel flow rate to compensate for the additional air flow.
I hope this answers your question.
Tony
Thanks, yeah that makes sense optimal A/F for an NA engine should be around 13.2 safely. I think it should be fine, I don't have any other mods like headers or test pipes that would lean me out.
Old Dec 2, 2006 | 03:41 AM
rnbanjao's Avatar
rnbanjao
can this combo be used with force induction (supercharger)...???? thinking of getting supercharger (vortech) soon but still saving $$$.. i'm interested on installing these combo.. for sure i can afford this before christmas.. jes wanna know if i can use it with supercharger... don't want to waste money...
Old Dec 2, 2006 | 05:15 PM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
Not with the Stillen, but its compatible with everything else.
Old Dec 5, 2006 | 06:19 PM
JdMfREaK's Avatar
JdMfREaK
damn i just bought the mrev2 will be here on tuesday..reading this i gets me hyped! i cant wait i bought the aam plenum and the mrev2! yea!!!!! lol easy to install,yes?
Old Dec 6, 2006 | 02:42 PM
sunset's Avatar
sunset
Originally Posted by PPW Z33
I know this has been covered so many times but I keep getting mixed responses, I know the 5/16 spacer is good for both but is the mrev2 with the spacer the optimal setup for the 287 hp?
According to the question/answer section I was reading in...the non-rev 287HP engine is better with MREV2 only from what I read. Is this correct? I am possibly ready to buy, but want to make right choice
Old Dec 6, 2006 | 08:21 PM
Rick06Z's Avatar
Rick06Z
Old Dec 6, 2006 | 08:59 PM
SLoG35's Avatar
SLoG35
Originally Posted by Rick06Z
Its the other way around. 287HP engine is best with spacer only (you already have the non-rev up lower plenum). MREV2 is for the rev-up and it s/b used with the spacer.
hmmm...thats funny b/c i heard the mrev2 is better for the 287HP engine too
Old Dec 6, 2006 | 09:46 PM
Abishop's Avatar
Abishop
No, the spacer is what gains most of your hp on a 287, only small gains with mrev. The Rev up gains more from MREV then spacer.
Old Dec 7, 2006 | 02:59 AM
cowzrul's Avatar
cowzrul
I have just about read all these threads on MotorDyne and thats what I thought too. non-revup 287hp gains most from spacer and rev-up 300hp gains most from MREV2. The rev-up sees nice gains from combining spacer and MREV2 but the largest gain is from the MREV2.
Old Dec 7, 2006 | 03:30 PM
Rick06Z's Avatar
Rick06Z
Old Dec 7, 2006 | 04:56 PM
DanielW's Avatar
DanielW
spacer for the non revup
Old Dec 7, 2006 | 04:57 PM
DanielW's Avatar
DanielW
420 posts hahaha
Old Dec 7, 2006 | 07:44 PM
Hydrazine's Avatar
Hydrazine
Hi guys,
On the 287 engine, for area under the curve, the MREV2 actually makes a little bit more than even the spacer. But the difference is pretty small.
The spacer makes about 1-2 HP more at the peak, but the MREV2 makes 1-2 more TQ with a little more midrange.
You could do either one and get pretty much the same results, they both predominantly add top end. There is a little bit of a trade off between them though.
1) the spacer has very good stealth and a little more bang for the buck.
2) the MREV2 has 100% stealth and a little more area under the curve.
And no matter what you do, if you have a REVUP engine, do both!
Old Dec 7, 2006 | 08:02 PM
derek173's Avatar
derek173
So on a 287 what could we expect in gains with Mrev2 + Spacer?
Hi guys,
Old Dec 7, 2006 | 08:22 PM
Hydrazine's Avatar
Hydrazine
I posted dyno plots of it several months ago.
Assuming the A/F is within nominal, it made 2-6 HP at various parts of the curve.
Old Dec 7, 2006 | 08:25 PM
derek173's Avatar
derek173
ok, thanks ill search for it, already recieved my mrev2 (thanks). I also have a utec, from what I have been reading in the tuning forums I should be shooting for a 13.0 A/F ratio?
Old Dec 7, 2006 | 08:30 PM
Hydrazine's Avatar
Hydrazine
Yes. But every car will work best with a little more or a little less. Only a careful tune will show exactly what is needed for your car.
Tony
Old Dec 7, 2006 | 08:52 PM
  #38
derek173's Avatar
derek173
Thanks, we love having vendors like you around who make great products and are honest! helps when you have X-mas sales too!
keep up the good work
Tony
Old Dec 8, 2006 | 12:52 PM
  #39
RBlover69's Avatar
RBlover69
....any idea why theres a iso thermal,. is that the perfereed due to the heat properties being more tolerant.
Old Dec 8, 2006 | 09:34 PM
  #40
Hydrazine's Avatar
Hydrazine
Thank you sir!
