How will these sound??
Old Feb 2, 2007 | 02:39 PM
Ilov350ZEE's Avatar
Ilov350ZEE
Default How will these sound??
how will the stock exhaust sound with test pipes, i already have a pop charger and will be getting plenum spacer pretty soon. My concern is how will the exhaust sound if there will be any rasp, if so at what rpm range?? also with the mods im going for will it give some lost of torque?
Old Feb 2, 2007 | 05:46 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
test pipes = rasp to some degree...tends to be in the mid rpm range. How much depends on the test pipe you do, and how much they lean your car out(different for everyone's car).
Old Feb 2, 2007 | 11:49 PM
VicPham's Avatar
VicPham
Lifetime Member
The stock exhuast sounds good with the tesp pipes. But since you got the rev-up model it would be better if you got the MREV2 + Plenum Spacer combo. And with the Pop Charger also. I think you will like the results.
Old Feb 3, 2007 | 01:29 AM
Cannysage's Avatar
Cannysage
make sure to get resonated testpipes..
Old Feb 3, 2007 | 04:11 AM
Ilov350ZEE's Avatar
Ilov350ZEE
im getting non resonated pipes with stock exhaust. I have non-revup.
Old Feb 3, 2007 | 04:52 AM
Like this: waroooooooooooooooom...waroooooooooooooooom...warooooooooooo ooooom...
Old Feb 3, 2007 | 05:51 AM
Zridder19's Avatar
Zridder19
its not too raspy, i have stillen non resonated test pipes on stock exhaust, and the only hint of rasp i get is right around 3 to 3700 rpm. i think that it sounds pretty good. you cant hear the rasp outside the car tho... sounds like an amplified stock exhaust.
Old Feb 6, 2007 | 03:23 PM
erickim080387's Avatar
erickim080387
rofl!
Old Feb 6, 2007 | 06:36 PM
titanjc's Avatar
titanjc
The stock exhaust sounds good with test pipes. It's definitely louder, and sounds pretty mean. The only thing is that you'll get a little hissing noise around 2000 RPM on deceleration in gear, which to me sounded crappy. Other than that though, it sounds great.
Old Feb 6, 2007 | 06:41 PM
BhamZMan's Avatar
BhamZMan
non-resonated = rasp
resonated = no rasp
It is that easy.
Old Feb 6, 2007 | 07:00 PM
Shift_Z33's Avatar
Shift_Z33
resonated = no rasp
It is that easy.
not with a stock exhaust, my Strup TP never had rasp until I added headers.
Old Feb 7, 2007 | 12:40 PM
Ilov350ZEE's Avatar
Ilov350ZEE
NR TP w/ stock exhaust will have NO rasp. Are you sure about this?
Old Feb 7, 2007 | 12:49 PM
clipso 01's Avatar
clipso 01
i have apexi n1 exhaust and strup tps and there is a lot of rasp between 3-4k
i can only imagine when i get headers oh boy
Old Feb 7, 2007 | 12:57 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
It will sound like the screams of a halibut getting pulverized in a blender
Old Feb 7, 2007 | 01:01 PM
titanjc's Avatar
titanjc
Hey Shift_Z33, are you saying your Strup non-res TP's didn't have rasp with the stock exhaust? If you're aftermarket, which are you running?
Obadabot
Jun 18, 2023 11:31 PM
sales@czp
Sep 23, 2019 03:30 PM
wanderingstuden
Jan 28, 2016 07:03 PM
Justin100
Nov 29, 2015 03:58 PM
samansharif
Sep 25, 2015 12:31 PM
