just installed kinextix plenum need help...
Old 02-14-2007 | 10:59 AM
arodbrs's Avatar
arodbrs
Default just installed kinextix plenum need help...
i installed the plenum last night with my buddy and as we test drove the z after it had a loud wistling sound to it, so we screwed the bolts back on super tight and it stopped it still sound like its leaking air a lil bit is that supposed to happen or whats the noise and the idling of my z is different now i also reset the ecu.....................need input z bros what could be the problem
Old 02-14-2007 | 11:01 AM
dvo's Avatar
dvo
is there a sequence of tightening the bolts? on the motordyne stuff there is a certain sequence so that you get an equal seal. just to make sure one side isn't tighter and level with the other side i guess
Old 02-14-2007 | 11:06 AM
teh215's Avatar
teh215
"super tight" is not a torque spec. You probably over-tightened them and are causing the leak you are trying to fix. Follow the instructions...
Old 02-14-2007 | 03:25 PM
THE TECH's Avatar
THE TECH
You also may not want to do installs "in da ghetto"
Old 02-14-2007 | 05:02 PM
Thumbs up
The bolts should be torque properly. The pattern resembles a star (similar to tightening lug nuts).
Old 02-14-2007 | 05:17 PM
Mike Wazowski's Avatar
Mike Wazowski
Old 02-15-2007 | 11:39 AM
arodbrs's Avatar
arodbrs
Default ..
Jerk................
Old 02-16-2007 | 10:54 AM
dvo's Avatar
dvo
ghetto? i i live in torrance but it's really LA. i live off of torrance blvd and western. a couple weeks ago there was a girl shot because she was walking down the "mexican" part of the neighborhood.
big difference from where i used to live. over by little company of mary hospital.
Old 02-16-2007 | 10:56 AM
THE TECH's Avatar
THE TECH
I wasn't the one who told everybody where I lived.
Old 02-16-2007 | 10:57 AM
joe645733's Avatar
joe645733
sucks for u to live over there.
Old 02-18-2007 | 04:37 PM
rx7/350z's Avatar
rx7/350z
yea i think those 10 mm bolts have to be torqued to 6-8 ft/lbs. if you overtighten you may have to get a new cork gasket
Old 02-18-2007 | 04:45 PM
Jay'Z's Avatar
Jay'Z
Did you purchase this brand new? If not then.. You may not have the gasket.. And the rule of thumb for tightening is to tighten with one hand as tight as you can....... Of course using the criss cross method for even seal..
07-10-2022 08:44 AM
Mattg350z
10-02-2015 07:51 AM
Quick Reply: just installed kinextix plenum need help...
