Err..Got a problem with my testpipes
Old Mar 5, 2007 | 04:03 PM
Pooplet's Avatar
Pooplet
Default Err..Got a problem with my testpipes *video*
I just had my resonated testpipes installed...When I rev up and the rev comes back down I hear a whistle/wheeze/rattle type of sound coming from under my car. I first thought it was exhaust rasp but the sound is produced under the car around where the TPs are. Is this normal or is there something wrong with the install...
Old Mar 5, 2007 | 04:50 PM
cubu's Avatar
cubu
probably got a leak, jack it up and tighten them up, make sure the gaskets are good
Old Mar 5, 2007 | 05:08 PM
bdrose's Avatar
bdrose
i had the same problem on my '06...had strups put on...that rattle bothered me so much..along with the smell...i took them off
Old Mar 5, 2007 | 05:11 PM
Pooplet's Avatar
Pooplet
I went back and the shop is saying that it is normal for the 350z ...apparently all of the ones they have worked on does this. Its more of a off pitch whistle/rasp on only when the rev comes down at a neutral reving. If it was a leak wouldnt I hear it when im driving?
Old Mar 5, 2007 | 05:17 PM
ldawg32's Avatar
ldawg32
i have the same thing with my exhaust and cats set up. when its cold i really hear it but when the cars warms up for a while it goes away and it only happens in low rpm range. i was told it was normal too but who know still sounds great other than that
Old Mar 5, 2007 | 05:25 PM
CNT350Z's Avatar
CNT350Z
Mine does that too with my test pipes or any aftermarket exhaust. Can you record what yours sounds like?
Old Mar 5, 2007 | 05:51 PM
Pooplet's Avatar
Pooplet
ill get a sound clip asap...its kinda annoying
Old Mar 6, 2007 | 01:50 AM
Pooplet's Avatar
Pooplet
video of the TP on stock exhaust/piping...All the video captured is the rasp because its not able to record bass/deep sounds..lame..Sounds pretty good with stock exhaust other then a small amount of rasp
http://youtube.com/watch?v=NtLYQmArLE8
http://youtube.com/watch?v=jWsaWjZW1PE
Old Mar 6, 2007 | 05:11 AM
MUZZY's Avatar
MUZZY
Check For Clearances If You Removed The Test Pipe Bracket Your Exhoust Is Able To Move More And Will Sag. It Could Hit Your Cross Support.
Old Mar 6, 2007 | 07:39 AM
da mayor's Avatar
da mayor
that sound i got from the backpressure going throught he test pipe
Old Mar 6, 2007 | 11:17 AM
fasttrack350z's Avatar
fasttrack350z
does it sound like a loose washer when the car rev down about 2k rpm? cause mine does that.
Old Mar 6, 2007 | 11:33 AM
Pooplet's Avatar
Pooplet
Yup...I made a poll thread about it.
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
