Center Plenum Bolts???????
Old Mar 10, 2007 | 08:08 PM
derek173's Avatar
derek173
Default Center Plenum Bolts???????
Do the six Center Plenum bolts just connect the top of the plenum with the bottom or do they thread down to the engine?
Old Mar 10, 2007 | 08:12 PM
supra crazy's Avatar
supra crazy
They just connect the upper and lower plenum.
Why did you strip yours? and your really worried?
Old Mar 10, 2007 | 08:18 PM
derek173's Avatar
derek173
no actually due to a stress crack I ended up modding my upper plenum. I removed the bolt posts on the inside and welded the bolt holes shut. I went to Start the car this morning and couldnt idle properly and kept dying. Since what I did was basically like Kinetix plenum (no center bolts) I thought it would work fine. However I check kinteix site to see how theirs is installed, I saw that they put smaller screws into the empty bolt holes on the lower plenum. I think this is my problem and I need to stick some bolts in there
Thanks
Old Mar 10, 2007 | 08:22 PM
supra crazy
yea I have a Crawford and they give you smalle bolts to put in thw holes that the stock plenum bolts went through.
Old Mar 10, 2007 | 08:25 PM
derek173's Avatar
derek173
cool, thanks I really appreciate your help. After the crack I went to order a crawford plenum.. and they no longer stock them Doug told me I could get on a waiting list but even if they get enough people it would be close to $500.
I hope this is the problem...... I have bolts that will fit in there hopefully plug and play, lol
Old Mar 10, 2007 | 08:33 PM
supra crazy
Yea well if you cant get the ones for the Crawford plenum I know the kinetix has them aswell. The Crawford only has 4 small molts because they still have 2 long center bolts. The Kinetixs on the other hand uses 6 so might as well get the kinetix bolts.
Old Mar 10, 2007 | 08:36 PM
__jb's Avatar
__jb
Z + Rear Seat
Might want to put a bit of Locktite on those bolts.
The CrawfordZ plenums come with those short block-off bolts in a bag with Locktite on them. It wouldn't be good if they came out.
Old Mar 10, 2007 | 08:39 PM
derek173's Avatar
derek173
The bolts from my spacer fit the bolt holes, I was just worried if I needed longer ones if they thread past the lower plenum.
Do you think these bolts not plugging the holes in the lower plenum are causing this? happened right after I put on the modded upper plenum, having a hard time understand why it would cause stalling but who knows?
Old Mar 10, 2007 | 08:44 PM
derek173's Avatar
derek173
I can tell you its not good if they are not there lol (I hope thats the prob)
yea got the loctite already
thank you
Old Mar 10, 2007 | 08:47 PM
2slo2bfurious's Avatar
2slo2bfurious
They are 30 cents a piece at ace hardware, I forgot the treadsize but just bring the old bolt and u can figure it out.
Old Mar 11, 2007 | 09:33 AM
derek173's Avatar
derek173
thanks will be heading there today, Ace is #1 when it comes to finding screws/bolts
Old Mar 11, 2007 | 09:03 PM
derek173's Avatar
derek173
Thanks everyone, I installed those bolts in the lower plenum and car is running great again.
sales@czp
Sep 23, 2019 03:30 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
