New Custom Plenum!!!!
Old May 2, 2007 | 08:05 PM
rpm06g35's Avatar
rpm06g35
Default haha diamondplate
haha well the diamond plate is not a huge people pleasing appearance. Oh well its not on your car. I made this to see just how hard it was going to be to fab around the back corner edges. My intention is to build a wilson style intake. You usually see them on mustangs and big motors. I dont know if I want to just get rid of the whole upper plenum all together. Its going to be kinda hard to get to the bolts if this thing is made to flow right. As far as this intake? I just dropped it off at the powder coater. I will have it on the car by sat. I'm not really interested in dyno numbers. I did what was basically stated earlier. Plasma cut the top, milled the deck and back (to get an easy weld) and welded in plates. The underside is smooth (no bolts for the center). Welp guys thanks for the comments mike
Old May 2, 2007 | 08:55 PM
Jes-Z's Avatar
Jes-Z
Great work mike, you are a hell of a welder! Let's smooth my plenum next!
Old May 2, 2007 | 10:31 PM
Reyes5937's Avatar
Reyes5937
So how much for the plenum.
Old May 2, 2007 | 10:36 PM
terrasmak's Avatar
I would wait for the results on the dyno if he decided to make some to sell.
Old May 2, 2007 | 10:48 PM
LHP's Avatar
LHP
If it works well, who cares what it's made from.
Well at least when you stand on it you won't slip.
LHP
www.haywardperformance.com
Old May 4, 2007 | 03:38 PM
rpm06g35's Avatar
rpm06g35
Default tooooooooo big
Welp you guys were right its too big for the hood to close on the g. However I will not let this thing beat me. I will deck the bottom of the lower intake manifold about a 1/4 of an inch or more. Depending on clearance issues. I realize i might actually take out the forward and aft bolt holes while decking the lower intake. That means I will have to weld some bungs for and aft. No problem. I just cant do it till monday. Welp sorry about this guys let me get it hammered out and I'll let you know how it goes. One question though. My 06 (rev up) lower intake is a little different than the old style (non rev up). I read some where that since the itake runners are so short I loose mid range power. I also read that if you go to the old stlye (non rev up) with the space it is considered optimum? Is this so and has anyone done this. I want to say motordyne said something about this. After all this stuff and trouble i think I will dyno it. Talk at you guys soon mike
Old May 4, 2007 | 04:37 PM
Reyes5937's Avatar
Reyes5937
I bet the plenum would fit under the hood of an FX-35
Old May 7, 2007 | 08:02 AM
Jun's Avatar
Jun
good job Mike!
Old May 7, 2007 | 07:36 PM
rpm06g35's Avatar
rpm06g35
welp I was on the lathe today for about 4 hrs. Man cutting down the bottom side of the lower intake manifold isnt all that easy. I was able to get a little more than 1/4 inch off of it. I tried to take pictures with my phone but they sucked a$$. I think i"m going to install tomarrow and see if the hood closes. Hope fully I wont need to cut more. I'm already having to add bungs to this thing. However in cutting this I noticed the upper and lower intakes (stock) are nowhere near being close to match. This is starting to get tricky. I'll post pics soon mike
Old May 8, 2007 | 07:30 AM
VO...'s Avatar
VO...
Administrator
Not feeling it too much, but kudos on the workmanship and creativity.
Old May 8, 2007 | 04:35 PM
gothchick's Avatar
gothchick
Not a fan of diamond plating, but the workmanship look tops. It'll be cool to see the HP gains on the dyno. :-)
Old May 8, 2007 | 04:42 PM
MR_X's Avatar
MR_X
at least is not slippery.
Old May 8, 2007 | 07:11 PM
turismo's Avatar
turismo
Its different thats for sure, but who cares. If it works it works. Let us know how it turns out.
Old May 8, 2007 | 07:18 PM
MI 35th's Avatar
MI 35th
OGPremierMafia
subbing for results and final pics. I am very impressed with you knowlege and creativity, not my style but fantastic job.
Old May 10, 2007 | 02:25 AM
rpm06g35's Avatar
rpm06g35
here are some pictures of the progress guys. The lighter section I scribed and ported(removed). thanks mike
Attached Thumbnails New Custom Plenum!!!!-how-much-to-remove-3.jpg   New Custom Plenum!!!!-notice-thickness2.jpg
Old May 10, 2007 | 02:51 AM
rpm06g35's Avatar
rpm06g35
last pic. notice the width of the both parts of the intake . I actually had to mill them both down. By doing this I managed to really mess up the flow of the not so good factory ports. So I ports matched the manifolds and gasket clearance wasnt an issue. more pics coming. mike
Attached Thumbnails New Custom Plenum!!!!-lower-intake-and-lower-intake-plenum-notice-width.jpg
Old May 10, 2007 | 04:30 AM
TENGAI's Avatar
TENGAI
You've got to dyno this afterwards. I'm really curious to see what the gains and power curves look like compared to stock/crawford/motodyne/etc...
Old May 10, 2007 | 10:41 AM
  #38
LG_z33's Avatar
LG_z33
I bet it loses power everywhere except the very top end, if anything. But I respect the hard work that it took to make something like this.
Old May 13, 2007 | 05:30 PM
  #39
rpm06g35's Avatar
rpm06g35
pics of cutting the lower intake. Should be ready to go by monday. Had to buy new gaskets and need to weld the holes shut on the lower side of the lower intake. results will be up soon later mike
Old May 13, 2007 | 06:09 PM
  #40
Jes-Z's Avatar
Jes-Z
U da' man mike. Great work, Can't wait for dyno results!
