Finally! Stillen Hi-Flow Twin Intakes for the VQ35HR!
Originally Posted by warmmilk
get before and after dyno's if u can
thanks for being the guinea pig
lol
I'm at 271whp right now with the nismo exhaust. I'll use that as a baseline I believe... When I can afford to get on the dyno, I will post
Originally Posted by evolved326
I hope they can sell me one side first cause I cant afford both at the same time.
Around the Oc its $60 fill up with premiem. Thats only 6.6 fillups =(
Thats why I only fill it up half way. And I also only pay half my car payments.
Lucky you who gets to pay half a payment. I also fill up half way, but it's also to increase MPG (weight) and spread out the $ a bit. Again these cars like any other sports class are expensive gas guzzlers. So be prepared!
A second job for gas might work? lol
Originally Posted by Gooey
wheres yoru dyno charts for the nismo exhaust?? I been planning on gettin mind dyno'd but have not found time to take the car to a shop
I'll make another thread on it when i have a chance have to scan the sheet
But if your baseline is 261, and you got 271 out of it with the exhaust, thats a 10hp gain with just the NISMO! that seems like a lot for the Nismo, which usually gives about 5-6hp. The Greddy EVO TT which is for FI gave 10hp as well. Is it possible that aftermarket exhausts give bigger gains on the 07 then previous models? Might explain why were getting more then expected out of the intake as well...
Originally Posted by ssnake86
Did you make an original thread with the scans? I searched and I found a thread where you scaned your stock baseline dyno chart. You put down 261hp/235tq. In that thread you said you were putting the exhaust and everything on hold cause your crawford cats wouldnt fit cause of the different flanges on the 07. Couldnt find a new thread where you dynoed it with just the exhaust.
I've dyno'd base again on a cooler day and hit 265 easy..so bumping up to 271 with the nismo is not unfeasible. I'll scan and post as soon as I can. Just plopped down a bunch of money on some other stuff so I'm pinching a bit until I get to the dyno.. I'm also looking into tuning this thing fairly soon to see if we can squeeze a bit more out of it..
Well my experience from going from an 06 to 07 the exhaust tone on the 07 is a bit different. Just a bit louder and a bit more rumble.
My nismo sounds like an Enzo when I really get on it.. very euro sounding but mean.. when i have SGP fab my test pipes, it'll get even crazier.. add the stillen intakes and it should growl bigtime..
You have to give +/- 2 for dyno difference/atmosphere/etc... I noticed a difference with the nismo for sure... hands down..
Sounds good, but dont you think you should wait on the tune tell you've installed more mods? Like HFCs or test pipes, remember you can get them to fit on an 07 with a little bit of work.
