testpipe issues
Old May 18, 2007 | 04:02 PM
gimpster621's Avatar
gimpster621
Default testpipe issues
i installed some ichiba test pipes and i get a loud virbation from the driver side. like right under my seat. what could the problem be? i made sure everything was tight and no leaks. i used brand new gaskets too.
Old May 18, 2007 | 07:56 PM
VIZAGE's Avatar
VIZAGE
When pressure builds, it causes it to vibrate against the heat shield. This is most likely what you hear. Some systems lower everything a bit, while others raise them. It seems like I've been through everyone of these scenarios with header,tp, and exhaust.
Try putting several wraps of heat wrap around the area to help. This will go a long ways but you might still tell it's there. It's not that bad though. You'll forget about it in due time. But try this, it works. This is the wonderful world of modification!
Old May 19, 2007 | 12:38 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
probably rasp or it could be rattling against your heat shields down there.
Old May 19, 2007 | 01:28 PM
ISMSOLUTIONS's Avatar
ISMSOLUTIONS
^^^ +11111
Old May 19, 2007 | 06:07 PM
gimpster621
alrite thanks guys. im going to try the heat wrap.
Old May 19, 2007 | 09:14 PM
soleil's Avatar
soleil
NolaZcc
just install my tp's today and same problem....doing the heat wraps tomo..
Old May 21, 2007 | 03:21 PM
gimpster621
^did it work? im soo busy these days im driving with the vibration for now til the end of this week
Old May 21, 2007 | 03:28 PM
wckdclw's Avatar
wckdclw
where do you guys get the heat wrap, i cant seem to find any in stores and i have the same problem
Old May 21, 2007 | 04:15 PM
THE TECH's Avatar
THE TECH
The Gimp seems to always be having some sort of exhaust related problems. Sorry Gimp.
Old May 22, 2007 | 02:30 PM
gimpster621
^actually i took it to the shop today, the test pipe was rubbing on the head shield and melted into it LOL. he got if off and readjusted it all for 10 bux! its called RENE's Mufflers on pasadena off of the broadway exit on the 5. excellent work and crazy price =D. now the car is fine cept the rasp around 4k but i guess i gotta live with that.
apex locator
Jul 23, 2021 02:27 AM
sherm
Apr 11, 2020 05:21 PM
350z82
Oct 1, 2015 06:25 PM
Depravity
Oct 1, 2015 04:49 PM
