dirty exhaust tips
Old Jun 2, 2007 | 05:28 PM
03aeroZ's Avatar
03aeroZ
Default dirty exhaust tips
quick question, if i get aftermarket exhast, will that reduce the amount of black crap that makes my stock tips so freaking dirty? also, what the hell causes that? too lean/rich? and yes, i did do a search and nothing came up. thanks
Old Jun 2, 2007 | 05:41 PM
robbinthehood's Avatar
robbinthehood
no you usually get carbon build up on an exhaust. are you catless? How long does it take for there to be a noticeable amount of build up on the exhaust?
Unless your cats are bad or you have a bad o2 sensor its normal. And changing your exhaust wont do anything.
Old Jun 2, 2007 | 05:42 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
solution: clay bar and aluminum polish
Old Jun 2, 2007 | 05:43 PM
03aeroZ's Avatar
03aeroZ
did it today, it will be dirty in less than a week
Old Jun 2, 2007 | 05:44 PM
03aeroZ's Avatar
03aeroZ
if it is a bad o2 sensor or cats....is that covered under the powertrain warrenty?
Old Jun 2, 2007 | 05:50 PM
robbinthehood
most likely yea. but unless your getting cel's or something its just normal. Have you changed anything on the fuel system or even the plugs? If they arent gapped right you might be running rich or maybe you adjusted your fuel pressure too high?
I really think its just normal unless you have a cel and if you do it should be covered under warranty.
Old Jun 2, 2007 | 05:54 PM
03aeroZ's Avatar
03aeroZ
no light ever. it did it when i first got it, still does it after a spacer/pop charger. ran few tanks of fuel system cleaner. it really only takes like a week. could try the plugs...but could this really be the cause? thanks for all the help
Old Jun 2, 2007 | 06:02 PM
mikead_99's Avatar
mikead_99
I really don't get this whole black residue on the exhaust thing. It's almost as if something has been burnt upstream of the tips and passes through them.
Old Jun 2, 2007 | 07:20 PM
No. The primary component for cleaning is the catalytic converter.
Carbon.
Old Jun 2, 2007 | 10:34 PM
gsazabi's Avatar
gsazabi
Don't worry it's normal. You will see at least a little bit of black residue on any Z or G coupe. Better running just a little rich than lean.
My solution: Titanium tipped muffler. It won't look as bad since it'll blend in lol
Old Jun 3, 2007 | 05:44 AM
Z04's Avatar
Z04
come to think of it, i have not seen a car yet that does not have some degree of black on the exhaust tips.
Old Jun 3, 2007 | 07:45 AM
03aeroZ's Avatar
03aeroZ
this is thick and covers the edge of the tips....it looks like i painted them that way. so if it is bad cats....is that covered under the powertrain warrenty?
Old Jun 3, 2007 | 07:49 AM
mikead_99's Avatar
mikead_99
I think what everyone is telling you is this is not bad cats, but perfectly normal. If you are really concerned it is the cats, go have a sniffer test done.
sales@czp
Sep 23, 2019 03:30 PM
Justin100
Nov 29, 2015 03:58 PM
nanotech
Oct 2, 2015 05:02 AM
Li1ag
Sep 28, 2015 02:07 PM
