06 vs 07 exhaust differences?
Old Aug 6, 2007 | 01:58 PM
powermark's Avatar
powermark
Default 06 vs 07 exhaust differences?
I tried searching, couldnt find anything.
Where is the differences in the exhaust design on the 07 vs the 06? (after header)
Old Aug 6, 2007 | 02:07 PM
MarkM's Avatar
MarkM
07 has a longer header design, shorter cats and an extended Y pipe. any exhaust will attach to an 07 car cat back, an 07 exhaust will not fit any previous years afaik
Old Aug 6, 2007 | 02:39 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Agreed...
07: better header design, smoother y-pipe design, the rest of the exhaust is pretty much the same
Old Aug 7, 2007 | 03:49 PM
powermark's Avatar
powermark
cats are built into the headers? I forgot.
so after the headers back, ( Y pipe to axle back) from an 03-06 will fit an 07?
Old Aug 7, 2007 | 03:52 PM
WalkerT's Avatar
WalkerT
Professional
Yes but why would you put a 03-06 on a 07?
The Y pipe also has vibration isolators.
No the headers are not built in.
Old Aug 7, 2007 | 04:00 PM
WalkerT's Avatar
WalkerT
Professional
Here I took a pic for you. Two vibration isolators and you notice the Y is straight until the mid pipe then joins just before going into the mid pipe. Much smoother flow.
Old Aug 7, 2007 | 04:05 PM
WalkerT's Avatar
WalkerT
Professional
Here is another looking back from the CAT
Old Aug 7, 2007 | 06:42 PM
aloh's Avatar
aloh
what do the vibration isolators do? how does it work? I wonder if it would be worthwhile to put them onto an aftermarket exhaust if it reduces any vibrating.
Old Aug 7, 2007 | 08:19 PM
powermark's Avatar
powermark
thanks guys, im asking because I am looking at the bassani catback but only showed it listed for an 03-06
Old Aug 8, 2007 | 02:00 AM
WalkerT's Avatar
WalkerT
Professional
It works by counter balancing the vibration. It would be to much work to weld them on an after market exhaust. The rubber is weighted and suspended off of the bracket. When they vibrate the rubber shakes at a different speed than the exhaust so they balance out or delete every other vibration. = smoother.
sales@czp
Sep 23, 2019 03:30 PM
350z82
Oct 1, 2015 06:25 PM
