check out these 2 velocity stacks
The one on the right is Stillen and the one on the left is from the popcharger.
The one on the left is thicker and the diameter of the opening is a little bigger
Which one do you think works better?
see next post
see next post
No, the one on the right is the one from Stillen. It is heavier, wider, yeah little more curve. And it also has those lines/gaps on the outside that probably make it have a better grip on the filter. The popcharger doesn’t have it. maybe that’s why there have been some people complaining that the filter has fallen out
Any Other Coments??????????
I think i'm going to use the stillen velocity stack (right one on picture) on the popcharger filter,
and use the stillen heat shield. it probably doesn't make any difference but since i had the 2 i wanted to make the best combination
