Ti-C melting my bumper
Old Aug 20, 2007 | 11:34 PM
D'sNuts's Avatar
D'sNuts
Default Ti-C melting my bumper
so went down to Show Stoppers today picked up a Greddy Ti-C and installed it on my 07... Everything went well installing didn't take to long since the car is really new took it out for the night after that and probably made about 4 different trips around town going a little faster than normal at times and giving it some high revs just to see how the bad boy sounded(sounds real good). Came back home and went behind the car to check it out again and notice that a fat piece of bumper has been melted down and bent in some odd form.. i have no clue what could have happend the install went perfect, from what i have seen by others the tip stood out just fine, I didnt go over any speed bumps or big dips... help me out here has anyone ever seen this and what am i supposed to do now? thanks in advance...
Ah yes looks great!
and then i go to the back and see this!
Old Aug 21, 2007 | 12:00 AM
Proteus's Avatar
Proteus
Im considering this exhaust for my 07 Enth. If this is a common issue -- is there some sort of material that can be used to 'shield' the heat? I'm really set on this exhaust.
Old Aug 21, 2007 | 12:18 AM
INDOMANZia's Avatar
INDOMANZia
damn ouch man...
Old Aug 21, 2007 | 01:44 AM
taurran's Avatar
taurran
Wow... first time to see that. Well, there's a company out there that makes CF heat shields for the exhaust but I forget who it is off hand. Or, you could buy a rear bumper or apron.
Old Aug 21, 2007 | 02:27 AM
Azn_Empurio's Avatar
Azn_Empurio
thats weird, the worst ive seen is like black marks that are removable, but never like this
Old Aug 21, 2007 | 02:38 AM
SuperBlack350z's Avatar
SuperBlack350z
when you rev, does the exhaust move around a lot? Make sure it doesn't move as much as those cheap hondas do because that will certainly do damage when you are wide open throttle or just revving.
Old Aug 21, 2007 | 04:00 AM
Delako's Avatar
Delako
I had that problem with an older car of mine when i got new pipes put in. I just exteneded the length and inch or two and that solved it.
Old Aug 21, 2007 | 04:47 AM
Ruthless18x's Avatar
Ruthless18x
damn that is pretty bad
Old Aug 21, 2007 | 07:27 AM
The end of the exhaust is too short failing to move the exhaust gases away from the rear bumper.
Old Aug 21, 2007 | 08:00 AM
D'sNuts's Avatar
D'sNuts
well this sucks.. anyone know how i can get a replacement bumper i doubt its repairable since the plastic is actually melted to its new shape.. I dont believe the exhaust is moving up and down but ill duouble check.
Old Aug 21, 2007 | 08:08 AM
Ed 718's Avatar
Ed 718
BRAVEHEART
Wow I am using the same exhaust with the INGS rear bumper which is fiberglass and nothing like what you have on the picture. I better check agan to see if I missed something.
Old Aug 21, 2007 | 08:10 AM
fast kiwi's Avatar
fast kiwi
Ahh bugger..
Old Aug 21, 2007 | 08:13 AM
Chebosto's Avatar
Chebosto
just get some aluminum sheeting and cut / rivet a heat sheild over the melted part. you should be ok. yea that tip looks kinda short.
Old Aug 21, 2007 | 08:23 AM
HondaKiller's Avatar
HondaKiller
They "can" remold the bumper by reheating the plastic and stretching it back into place. It is a common practice for Toyota's, but it wont solve your problem. I know there aren't too many ways to mount the exhaust on these things, but check your rear exhaust hangers, see if you can tweak them slightly to pull that pipe away from the bumper a half inch or so. That may help you.
Old Aug 21, 2007 | 08:24 AM
bb1314's Avatar
bb1314
da Terminator!
Get an ING rear bumper.
Old Aug 21, 2007 | 08:35 AM
fairlady350z33's Avatar
fairlady350z33
wow that looks bad, try adjusting the muffler or tip to see if you can get it out past the bumper so the gases won't collect under the bumper and melt it. good luck
Old Aug 21, 2007 | 08:48 AM
D'sNuts's Avatar
D'sNuts
thanks guys.. heres some more pics of the carnage in day light..
Old Aug 21, 2007 | 08:51 AM
sofa king's Avatar
sofa king
good god! i dont have that problem at all. do you have aftermarket cats or a y-pipe?
Old Aug 21, 2007 | 08:59 AM
D'sNuts's Avatar
D'sNuts
nope everything is stock on the 07 except for this Greddy y-pipe back exhaust...
Old Aug 21, 2007 | 09:22 AM
Carry a fire extinguisher just in case.
