exhaust gasket
Old Oct 10, 2007 | 06:14 PM
Ilov350ZEE's Avatar
Ilov350ZEE
Default exhaust gasket
will the stock exhaust gasket fit on Nismo exhaust???
Old Oct 10, 2007 | 07:39 PM
jonnylaw's Avatar
jonnylaw
It will "fit" but the gaskets will be smaller than the diameter on ur nismo exhaust, impeading airflow.
You want this:
http://www.mynismo.com/products/?id=4118
or something smilar, with the correct matching diamether of the nismo exhaust.
Old Oct 11, 2007 | 02:53 PM
Ilov350ZEE's Avatar
Ilov350ZEE
ok so it will fit, but will be smaller. SHould i go a head and use the stock ones???
Old Oct 11, 2007 | 02:57 PM
DavesZ#3's Avatar
DavesZ#3
Only if you want to induce restriction to the flow
Old Oct 11, 2007 | 03:06 PM
Ilov350ZEE's Avatar
Ilov350ZEE
not a good idea huh, seller says he used the stock and had no problem.
Old Oct 11, 2007 | 03:55 PM
StreetOC192's Avatar
StreetOC192
well you may not have a "problem" using the stock ones but you will not be getting the most out of the new exhaust......which is the whole reason you bought a new exhaust. Spend a few dollars on some new gaskets. you can get them at any local auto parts store if you know the exact pipe diameter.
Old Oct 11, 2007 | 04:02 PM
DavesZ#3's Avatar
DavesZ#3
Did he have a problem - of course not. But since you paid for a NISMO exhaust with 76mm piping why restrict the flow with a 60mm gasket.
Old Oct 11, 2007 | 05:34 PM
Ilov350ZEE's Avatar
Ilov350ZEE
the nismo im buying doesnt come with bolts and gasket. What size gasket do i need and will any bolts work??
burglapfd
Dec 6, 2020 01:04 PM
sales@czp
Sep 23, 2019 03:30 PM
Justin100
Nov 29, 2015 03:58 PM
Li1ag
Sep 28, 2015 02:07 PM
