SRD write up of MREV2
Old Jan 30, 2008 | 11:57 AM
Regul8or's Avatar
Regul8or
Default SRD write up of MREV2
Hey guys,
I hope this is not a repost, but I was looking around for info on the MREV2 and run across this article. Great read. Also for you guys with this combo( MREV2 and 5/16 spacer), in the article it said that the top end loss would be alleviated with exhaust, is that true??
btw, I have the Nismo and recently purchased an MREV2 and 5/16 iso spacer.
Here is the link :
http://www.envisionelite.com/mrev.html
Thanks,
Regul8or
Old Jan 30, 2008 | 12:47 PM
BakaN20's Avatar
BakaN20
I don't really have any topend loss. My peak with mrev2+spacer drops down to my peak on my baseline. If you want, i can post my dyno. I also hve a nismo exhaust.
Old Jan 30, 2008 | 12:52 PM
Mazinger Z's Avatar
Mazinger Z
Makes me want to get my car dynoed, I have the mrev2 + 5/16 spacer, fast intentions res. tps and borla exhaust. I wonder if the drop on the top end is similar to that posted dyno.
Nontheless, I rarely get to redline so... :shrug:
Old Jan 30, 2008 | 02:42 PM
HR Autoparts's Avatar
HR Autoparts
HR Autoparts
50hp to the wheels lol, you got all the basic bolt ons, getting a reflash would help alot
Old Jan 30, 2008 | 06:33 PM
Regul8or's Avatar
Regul8or
I would greatly appreciate it. I will be running the exact same setup next week. Thank you
Old Jan 30, 2008 | 08:40 PM
BakaN20's Avatar
BakaN20
https://my350z.com/forum/showthread....323060&page=11
Refer to that thread about the mrev2. MRC tried to keep everything constant.
Old Jan 30, 2008 | 08:45 PM
mrg1981's Avatar
mrg1981
This is a write up from the shop doing all of the work on my car. The car tested is one of the owners' G35. The MREV2 seems to be a great mod for NA VQs. I think the exhaust got rid of the top end problem, to answer your question. They have done the MREV2 on a lot of VQ's at SRD and they have seen good results from all of them.
If you hit them up for a quote, I'm sure they'll take care of you as they did me!
Old Jan 30, 2008 | 10:47 PM
ke0ki2k's Avatar
ke0ki2k
beautiful dyno 3kgts
Old Jan 31, 2008 | 08:37 AM
Regul8or's Avatar
Regul8or
Wow, I love it 3kgt, I have seen this before on Motordyne's site, but I did not know it was your car. I was actually going to ask a question about whether or not the car had exhaust. Im excited about putting them on next week! After these mods, our rev-up motors are not so obsolete after all
Old Jan 31, 2008 | 04:10 PM
BakaN20's Avatar
BakaN20
Thanks I don't race or anything, and I actually didn't want to do anything to my car, but this was too good to pass by. It was with the iso thermal parts, and the copper throttle body spacer wasn't put on. I put the z to sleep for the winter afterwards, but any questions about this, i'll answer the best to my ability.
Old Jan 31, 2008 | 05:47 PM
sry110's Avatar
sry110
Looks to me like the mrev by itself (green curve) is slightly higher than the mrev+spacer up until about 5120 RPM?
Old Jan 31, 2008 | 05:58 PM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
Yes. And that's the usual trend.
Adding a 5/16" spacer to the MREV2 decreases the TQ slightly and increases the HP. And using a 1/2" spacer adds a little more tilt to the curve but only increases the top end HP by about 1-2 HP more.
Old Jan 31, 2008 | 06:01 PM
Regul8or's Avatar
Regul8or
Yea i guess thats the case, but the biggest reason for the spacer is to relieve all the high end lost due to the MREV2, which it clearly does according to the dyno, but it needs exhaust as well. This dyno is with a Nismo exhaust. Look at the original post and the link of SRD's write up. They also have a great sound clip
Old Jan 31, 2008 | 06:18 PM
sry110's Avatar
sry110
I might just treat myself to one of these MREV2 animals when spring rolls around. I have a JIC y-pipe and fujitsubo exhaust so I am thinking that should eliminate any of the top-end breathing problems. But 3kgtsflip's dyno was done with a Nismo cat-back on, and he was still making less-than-stock numbers at the top end past about 6100 RPM? I read through the thread but I'm still confused...I'm not sure I want to sacrifice my top end power for some more mid-range
Old Jan 31, 2008 | 06:53 PM
2K5G35C's Avatar
2K5G35C
I thought that too, but when you consider the fact that the bulk of our driving is not done at top end, it makes lots of sense to try and maximize hp at mid-range, where most of our driving is done. I just read a magazine write up done with a an MREV2, a 5/16 spacer, a Stillen full catback, and a Stillen inatke. I'm definitely getting the catback next, and then an ECU reflash.
Old Jan 31, 2008 | 08:04 PM
BakaN20's Avatar
BakaN20
I lose about 2whp for around 300-400 rpms then it returns back to baseline from 6600 afterwards. Thats not much of a lose. Underneath the curve, in some areas I make around 110-6whp for about 1000rpms and there is improvement from 3500rpms all the way to 6100rpms, and it just dips for a couple hundred like i said, and goes back to what the baseline peak was. So there isn't really any sacrifice to the topend at all with a nismo exhaust it seems. In the Got Mrev2 thread, there is bigger pictures of the dyno if you want to see more details of it. Its on page 11 i believe.
TrboMike
North East
Sep 28, 2015 06:36 PM
torchkc
Sep 11, 2015 08:26 PM
GettinOnIt
Sep 23, 2002 11:04 PM
ZThang
Aug 28, 2002 06:53 PM
