what tool do i need to install (HFC,exhaut and spacer)
Old May 11, 2008 | 05:06 AM
Darkness75's Avatar
Darkness75
Default what tool do i need to install (HFC,exhaut and spacer)
hi all ,
first thing to know that this will be my first time to work under a real car (my experience is fixing n tunning RC cars engine) .
i`m thinking of installing Berk HFC and APS 2.5 true dual exhaust on my `05 350Z ,so what are the tool`s that i need to do that ? every thing i`ll start from scratch (tool size`s(1" to 5.5" like that ) ,jack ,jack stands , boards ,lubricant (PB Blaster or WD40?) ,wrench ,thread lock if needed (how much should i use ? ) ......etc) i know the name`s from the threads but i did searched for those i came up with alot of options witch one should i get ?
so if you guys can help me with a list (pic`s if possible that would be a dream come true)
and if there is a steps i should follow to do that (first HFC then down pips then muff .... if that would make a difference)
i`v searched about installing exhaust i found a lot of bad experience like this one :
https://my350z.com/forum/intake-exhaust/357773-my-failed-invidia-n1-install-exhaust-work-ftmfl.html
what should i do to avoid that
or should i just take it to a shop ?????????? (please don`t let me down guys )
Old May 11, 2008 | 07:13 AM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
For exhaust,
2-3 foot extension.
14mm short, deep and swivel
14mm wrench
Breaker bar
And don't use thread lock on exhaust bolts. You can use lock washers if you want.
For spacer.
All tools are listed in the installation manual.
Old May 11, 2008 | 07:17 AM
jeffie7's Avatar
jeffie7
Here's your answer =)
Old May 11, 2008 | 11:57 AM
Darkness75's Avatar
Darkness75
Originally Posted by Hydrazine
For exhaust,
2-3 foot extension.
14mm wrench
Breaker bar
For spacer.
thank you alot man thats so .....so helpfull
can someone tell me shall i install the HFC or its too hard for me as a beginner?
one more thing ,i noticed alot of threads talking about hessing and noise from the exhaust is there something i should take care of ??
and thank you again guys
Old May 11, 2008 | 12:25 PM
350ZTheStandard's Avatar
350ZTheStandard
Did you read the destructions in all of the manuals, they list tool needed.
Old May 11, 2008 | 03:35 PM
05Z33's Avatar
05Z33
You should be fine doing this on your own. Just take your time. The removal of the stock cats will be more of a PIA than the install of the Berks HFC. Also any exhast or muffler shop can swap them out for you for only 60-80 bucks. As long as you are not running test pipes you should not get any hissing. Good luck with your install.
Old May 11, 2008 | 08:24 PM
Hydrazine's Avatar
Hydrazine
I say do it. It will give you experience and its a good starting point.
None of it is complicated. It just takes a little time and patience.
You've already seen the problems people can run into, so now you know half the battle. Use a lot of spray lubricant before starting.
Even if you feel a little nervous starting, its really easy stuff. You'll be glad you did it.
Old May 12, 2008 | 03:57 AM
Darkness75's Avatar
Darkness75
thats very encouraging guys ,,,,,i`ll do it
i`ll try to take pics of every step i do in removing and installing the HFC & APS exhaust
also i`ll do 1) dayno in stock
2)dayno in HFC
3) dayno in HFC+APS
(but it will take time but i`ll post updates as i have something to share)
wish me luck guys
Old May 12, 2008 | 07:45 AM
PB Blaster
Any penetrating solvent is helpful. Spray all hardware the evening before.
Old May 12, 2008 | 07:49 AM
I hate laying under a car on jack stands. Maybe its too claustrophobic or I just wrestle with getting the correct angle on stuff.
If the car is on a lift I am fine.
phreaktor's Avatar
phreaktor
Design Engineer
Sharpened spoon
Tweezers
Bag of rubber bands
One paper clip
One box of wooden matches
Small collection of glass animals
Old May 12, 2008 | 07:56 AM
Old May 12, 2008 | 11:31 AM
gothchick's Avatar
gothchick
Originally Posted by phreaktor
Sharpened spoon
Tweezers
Bag of rubber bands
One paper clip
To properly freebase, you'll also need:
Cotton swab
Candle or Sterno
Clean Needle
Old May 12, 2008 | 11:33 AM
blasian's Avatar
blasian
For the HFC, you'll need an O2 sensor socket. I rented one from Autozone then ended up just keeping it.
Old May 12, 2008 | 06:01 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
you need at minimum:
some nice long extensions,
a flashlight
a friend
to install HFC
Old May 13, 2008 | 02:06 AM
Darkness75's Avatar
Darkness75
the tools ,the HFC and 2Pac CD mmmmm
i think i`m all set to install the HFC
but i have to make sure of one thing :
is this the metallic HFC ?? its white from the insaid !!!!
as you see in Berk Technology site they show both kinds (i think the black one is the metallic)
what tool do i need to install (HFC,exhaut and spacer)-metallic-vs-ceramic.jpg
or they are showing a used one ??
Old May 14, 2008 | 03:03 AM
Darkness75's Avatar
Darkness75
its metallic
conformed by bryan@berk
this guy is best in customer service
Old May 14, 2008 | 03:10 AM
Darkness75's Avatar
Darkness75
update :
i did i dayno (`05 350z stock ,non-revup motor 6600 redline)
i got 212 HP , the shop says it good ??!!
ill do another dayno after i install my HFC
Old May 14, 2008 | 06:07 AM
Hydrazine's Avatar
Hydrazine
Attachment 189468
That picture shows the metallic cat.
The metallic is the stainless steel metal foil used as the substrate and support.
The white stuff on the foil is the actual catalyist material. Its a mixture of ceramic and nano size particles of platinum, palladium, rhodium and other precious metals.
You can't see the precious metal particles because they are so small but the white stuff is the ceramic portion of what cleans your exhaust gasses.
All that stuff starts out as a slurry that is sprayed onto the substrate, dried and fired in a kiln.
Old May 14, 2008 | 11:31 AM
Darkness75's Avatar
Darkness75
thank you for the information
i appreciate that
