turbo xs with test pipes
Old Jun 22, 2008 | 03:14 PM
joe645733's Avatar
joe645733
Default turbo xs with test pipes
hey whats up guys. i order a turboxs exhaust about a week and a half ago. and turboxs STILL hasnt sent it out. but i saw a video of a z with the exhaust and test pipes. and was very raspy. sounded like crap..
so does anyone have a clip of the turboxs exhaust without the stock cats?
Old Jun 22, 2008 | 03:44 PM
Frostydc4's Avatar
Frostydc4
Lightbulb
I posted a vid not too long ago of the TXS on my G. Here is another vid of it on a Z with testpipes that sounds a little better http://www.youtube.com/watch?v=A1w-49A-jmg (go to 1:02 in the vid). I agree that it sounds very raspy but I'm willing to live with it for the noticeable power gains over my previous setup .
Old Jun 22, 2008 | 03:49 PM
joe645733's Avatar
joe645733
ya, that black z is the one i saw. he has another video of it pulling out of a shop or something. and just sounds really bad.
in that vid with the MS6 didnt sound too bad though. i was just seeing if anyone else had a video with different test pipes or even HFC's.
thanks for the help though
Old Jun 22, 2008 | 04:32 PM
Z_HighSpeed's Avatar
Z_HighSpeed
i think the vid u heard was mine...
the sound is much better now...it was colder weather then and the sound has progressively gotten better...its loud....very very loud.
Old Jun 22, 2008 | 04:35 PM
Quamen's Avatar
Quamen
I have strup headers/test pipes installed and a Turbo XS exhaust that should be here this week.
I am sure it will be very loud and raspy but I am going to try adding a muffler or resonator to smooth it out a bit and quiet it down.
It comes down to the fact that I need it for the power reasons on my supercharged Z.
Old Jun 22, 2008 | 04:41 PM
Frostydc4's Avatar
Frostydc4
This is the exact setup I have. Its very, very loud. You will be more than pleased with the power gains though
Old Jun 22, 2008 | 05:08 PM
joe645733's Avatar
joe645733
do u have the vid?
do u have a black Z?
Old Jun 22, 2008 | 05:16 PM
JOEGYVER's Avatar
JOEGYVER
I have turboXS exhaust and AAM non resonated TPs. I had a resonating vibration sound at low rpm that I could not eliminate, so I removed the testpipes, all tight new hardware, no leaks, no contact/interferences, just from resonating, sounded awful. Not sure what I will end up doing....
Old Jun 22, 2008 | 07:03 PM
Z_HighSpeed
do u have the vid?
nah mines silver...i gata try to find it
Old Jun 22, 2008 | 09:02 PM
Teufel's Avatar
Teufel
ANyone with Berk HFCs + TurboXS
Old Jun 23, 2008 | 11:15 AM
Frostydc4's Avatar
Frostydc4
I have this sound also . Its very noticable when the A/C is on especially when its hot outside. I looked under the car and the midpipe is not hitting the m-brace (I have about .5-.75" clearence). So removing the test pipes did not cure the problem? Also how much space do you have between the m-brace & the midpipe? Thanks.
Old Jun 25, 2008 | 05:53 AM
JOEGYVER's Avatar
JOEGYVER
Oh, yes back to oem cats fixed the problem. I had nearly an inch between the brace and midpipe. I had a friend rev the motor as I observed and could find no contact then either. I made brackets to reinstall the bracket to support the TPs that had supported the oem cats and also mounted the oem exhaust weighted dampeners to the turboxs exhaust, nothing helped. I even tried putting my foot on the y pipe with some pressure on it and reved it and even then, no reduction in vibration, dang crazy. I thought for sure the brace and dampeners would fix it, but no such luck. Maybe I will try some type of dampener on the TPs and give it another try, or install them one at a time to see if one is worse than the other...
issyz
Jul 2, 2017 03:04 PM
codek
Sep 28, 2015 03:03 AM
