Borla Headers & Exhaust DYNO topped at 232.60.....
Old Jul 22, 2003 | 03:45 PM
arvin's Avatar
arvin
Default Borla Headers & Exhaust DYNO topped at 232.60.....
torque. Yes baby!!!!!!!
I had my car dynoed today. Max horsepower is at 248.8 and torque at 232.6. I am happy with the results, considering my baseline dyno about 1 month ago was at 235hp and 228 torque.
ATP in Fremont, CA also did an air-fuel ratio reading. It is at 13.1, which they say is PERFECT.
Just like Borla said, there is not much more power on the headers, but If you can see the dyno chart and if I am reading it correctly, there is an definite increase in torque at around 3900 rpm.
Dyno run #1 is 4th gear
Dyno run #3 is 3rd gear
Old Jul 22, 2003 | 03:46 PM
arvin's Avatar
arvin
Hmmm.
How do you post pictures.
Please help!!!!!!!
Old Jul 22, 2003 | 03:47 PM
2003z's Avatar
2003z
convert them to .jpg and resize them to 640x480
Old Jul 22, 2003 | 03:54 PM
cbsuper's Avatar
cbsuper
Cool. Glad I picked them up. For the price you pay for them they give a pretty good hp increase.
Old Jul 22, 2003 | 03:56 PM
failsafe's Avatar
failsafe
....for your health
Hey Arvin- Did Su do the dyno's for you? Why did he have you do 3rd and 4th gear pulls? He's always had me do 5th gear pulls.
Old Jul 22, 2003 | 04:06 PM
arvin's Avatar
arvin
let me try this again
Attached Thumbnails Borla Headers & Exhaust DYNO topped at 232.60.....-dyno.jpg
Old Jul 22, 2003 | 04:24 PM
arvin's Avatar
arvin
I told him to pull in 3rd and 4th because my previous dyno was at 3rd and 4th. I wanted to compare both. Unfortunately, I only have a printout on paper of the previous run.
And they only charge $65 bucks. Cheap!!!!!
1st run 4th gear
2nd run 4th gear
3rd run 3rd gear
4th run 3rd gear
Old Jul 22, 2003 | 04:40 PM
pointfivezero's Avatar
pointfivezero
Charter Member #16
Hi Arvin;
It's your Coleman Circle neighbor to the north (about four blocks). Nice job on the post. Where did you purchase your Borla stuff? Who did the install?
I've been to Hanlee's several times but NISMO is a foreign word to them. Next time I see your Z in the driveway, I'll try to stop by.
Tim
Old Jul 22, 2003 | 05:04 PM
sojourn's Avatar
sojourn
Great results! I love seeing hard dyno numbers !
The scale on your graph really emphasises how the Z engine dies after 5,000RPM... At first i thought the engine must be suffocating but even the InJen post:
https://my350z.com/forum/showthread....threadid=37061
... shows the same drop after about 4,750... Anyone know what's holding the engine back? I can't imagine it's fuel related but what else could it be?
Old Jul 22, 2003 | 05:06 PM
2003z's Avatar
2003z
after 9000 miles, mine doesn't die like that quite as bad anymore on the top end.
Attached Thumbnails Borla Headers & Exhaust DYNO topped at 232.60.....-old.vs.new.jpg
Old Jul 22, 2003 | 08:35 PM
fdao's Avatar
fdao
Just a guess, but I believe it may be due to the rich condition and lack of air flow to the front cylinders that leads to what you see.
Old Jul 22, 2003 | 10:16 PM
OC_350Z's Avatar
OC_350Z
That's what I have heard too. The ECU has the engine run rich as you get to the redline to prevent engine damage. The air flow thing makes sounds right too. I hope an new intake + ECU mod can fix this.
Old Jul 23, 2003 | 08:43 AM
arvin's Avatar
arvin
hey Tim,
Drop by anytime.
Old Jul 23, 2003 | 08:50 AM
arvin's Avatar
arvin
Have you guys noticed the spike in torque around 3800 rpm? If I am reading it correctly, it is at 230 torque at 3800 rpm. Have you guys notice this on other dyno charts that does not have the Borla headers installed?
I also noticed that my air-fuel ratio dropped to about 12 on the higher rpms. Does this mean it is richer or leaner?
Old Jul 23, 2003 | 08:51 AM
Xeinth's Avatar
Xeinth
So 13 HP and 4 Torque for Borla headers and exhaust? Doesnt Injen SES do better than this with exhaust only?
X
Old Jul 25, 2003 | 11:27 AM
Buub's Avatar
Buub
According to Injen? Or according to someone having it independantly tested on their own car?
Old Jul 25, 2003 | 11:53 AM
SlamMan's Avatar
SlamMan
Nice! Looks like you got decent gains across the board.
Richer. 12 parts air to 1 part fuel
Old Jul 25, 2003 | 12:04 PM
SlamMan's Avatar
SlamMan
Yea but the HP number doesn't drop off till just before 6500. The car is still making good power till then. It's the stock cams that are dying off above 6.5K. A nice cam up grade would take care of the engine runnin out of breath. Then you would just run into the rev limiter. You would need a valve train upgrade and aftermarket ecu to take your rpm high enough to take the new cams to their limit.
Old Jul 25, 2003 | 12:06 PM
Monkey Man's Avatar
Monkey Man
Don't you have to convert the numbers because he did the pull in 3rd and 4th gear? I thought 5th gear was the 1:1 gear on our car. If so, the numbers would be slightly higher.
-Jeremy
Old Jul 26, 2003 | 02:47 AM
joust75's Avatar
joust75
If you do a simple proportions equation 248 at the wheels with respect to 235 at the wheels = 287 hp, then 248 = 302 HP at the crank!!! Cool
sales@czp
Sep 23, 2019 03:30 PM
Justin100
Nov 29, 2015 03:58 PM
Li1ag
Sep 28, 2015 02:07 PM
