MREV2 & 5/16" MD Spacer Installed
Old Jul 14, 2008 | 08:38 AM
kenpo_350Z's Avatar
kenpo_350Z
Nice write up and review. I think this a great mod to do. The customer service and help you get from the company (Hydrazine) should put anyone at ease thinking about doing this mod. Well worth it.
Old Jul 14, 2008 | 01:50 PM
OCG35's Avatar
OCG35
eh... Tony's alright...
j/k!!! One of the best customer service providers ever! Great products too
Old Jul 15, 2008 | 04:40 AM
Darkness75's Avatar
Darkness75
+100 tony from Motordyne and bryan from Berk ,,best customer service ,,
Old Jul 15, 2008 | 06:38 AM
JMS71585's Avatar
JMS71585
Originally Posted by sry110
I had to play with the strut bar setting a little bit to get ample clearance between the bar and the plenum. When I first went out for a drive I heard a slight vibration / rumble which I think was the bar rubbing the plenum, so I loosened it up a bit and the sound went away.
I have a quick question about playing with the "strut bar settings". I installed my plenum spacer and i notice a slight vibration/rumble resulting from the strut bar touching the plenum under heavy acceleration and during other random times. When you say you adjusted your strut bar, are you talking about adjusting that washer on the strut bar? ( boxed off in red, pictured below)
I was looking to get rid of the vibration/rumble too. Let me know what you did.
Old Jul 15, 2008 | 08:26 AM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
Its the middle bolt that you need to adjust. First loosen up the lock nuts on the left and right side of the tensioner bolt.
Then, while standing in front of the car, put a crescent wrench on on the tensioner bolt and pull the wrench toward you. When you do this you will see the strut bar move upward and away from your plenum.
This is what will give you the clearance you need to get rid of that vibration.
Old Jul 15, 2008 | 08:38 AM
JMS71585's Avatar
JMS71585
Excellent info right there!! I've been looking everywhere on how to adjust it, and if i can adjust it. Thanks!!
Edit: I put two washers/spacers under the strutbar for clearance. Could i take out those washers/spacers and adjust the strut bar to clear the plenum? Or should i just leave in the spacers/washers?
Old Jul 15, 2008 | 08:50 AM
Hydrazine's Avatar
Hydrazine
Its probably best to leave them in place. You should have something there to lift up the bar when a spacer is used.
Old Jul 15, 2008 | 08:57 AM
JMS71585's Avatar
JMS71585
Will do. Thanks again.
Old Jul 15, 2008 | 08:58 AM
sry110's Avatar
sry110
Are you talking abou the spacers that Motordyne sent you with the kit, or some other spacers / washers? I can't speak on anything other than the spacers motordyne supplied, but as far as I can tell the strut bar alone does not have enough adjustability to clear the plenum without using spacers underneath it.
Old Jul 15, 2008 | 09:21 AM
JMS71585's Avatar
JMS71585
I'm not going to take out the washers/spacers supplied with my spacer. I'll just adjust the strutbar a little bit for the added clearance i need. I just need to adjust the strutbar a hair, so it doesn't occassionally vibrate/rumble
Old Jul 15, 2008 | 09:42 AM
Hydrazine's Avatar
Hydrazine
As shown in his sig, JMS has the AAM spacer.
Old Jul 15, 2008 | 10:03 AM
JMS71585's Avatar
JMS71585
Yes, i have the AAM one, but either way, i now know how to adjust my stut bar. Thanks again...
sry110's Avatar
sry110
Noted
Old Jul 16, 2008 | 11:27 PM
350ZTheStandard's Avatar
350ZTheStandard
So now that I have done my install also I notice that the bottom end has a much stronger pull, also the engine idle stays at about 1k now & before it was about 750 - 800 rpms. Anybody else notice this, is the gas mileage also going to be worse than before the mod? I realize now the milage is slightly different, but hoping i will eventually idle like before & the mileage will come back to me. I also cleaned the throttle body with a full can of carb cleaner, I suppose this was a good thing, right???
Old Jul 17, 2008 | 05:00 AM
Hydrazine's Avatar
Hydrazine
Cleaning the TB can cause the change in idle. Try the TB calibration reset procedure.
Gas milage will be better if you drive exactly the same as before. But if you slam the gas pedal and use the extra power the mod makes, your MPG will go down.
Old Jul 17, 2008 | 05:55 AM
sry110's Avatar
sry110
I have been keeping my eye on the mpg meter over the past week since I installed this stuff, and i have noticed that under normal 'tame' driving my gas mileage has gone up maybe 0.2 or 0.3 mpg on average. For my mixed highway / town driving (I live in the suburbs) I used to get about 20.6, now I'm up around 20.9. Of course once in a while my foot gets sucked to the floor and I'm right back down to 20.6 : )
Old Jul 17, 2008 | 08:39 AM
Hydrazine's Avatar
Hydrazine
Very good test you did there.
That's what I measured with well controlled test conditions, on a load dyno.
Having the luxury of using a load dyno, with a Cipher data loger, to control/monitor the many variables, makes it a lot easier to hold test conditions constant.
Old Jul 17, 2008 | 10:34 AM
  #38
RBlover69's Avatar
RBlover69
one day we need to get a stock revup vrs a 5/16th mrev2 revup so we can see the pull. I been waiting for a vid for the longest. Someone hook it up. If any revup wants to run me with a revup mrev2 and 5/16 i would love to here it and vid it . its long over do.
Old Jul 17, 2008 | 11:20 AM
  #39
Hydrazine's Avatar
Hydrazine
No videos that I know of, but it's been independantly dynod countless times. Many of the plots are shown in the dyno section of the MD website.
The latest pre/post dyno I know of was by Julian @ MRC.
He posted his results in this forum just a few months ago. Did you see his test results?
Its the dyno plot at the bottom of the page in the dyno section of our website.
http://motordyneengineering.com/imag...page_large.jpg
Old Jul 18, 2008 | 12:34 AM
  #40
h3av3ndeath's Avatar
h3av3ndeath
im kinda of a noob at this but i got the powerlab plenum spacer, is it possible to use the mrev lower manifold along with the powerlab plenum?
