MREV2 & 5/16" MD Spacer Installed
Old Oct 15, 2011 | 06:54 AM
  #121
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
That's a Copper Iso Thermal kit.
Install it. With this kit you don't have to make any adjustments to the Coolant Control Valve (CCV). Its all automatic. Install it and forget it.
Old Oct 16, 2011 | 06:39 AM
  #122
sry110's Avatar
sry110
LOL ok that's what I thought. Refresh my memory: can I get the throttle body off and put this in without removing anything but the intake tube?
Old Oct 16, 2011 | 06:52 AM
  #123
Hydrazine's Avatar
Hydrazine
Only with great difficulty. Its been done but its very tight in there.
You pretty much need to take the upper plenum off, but that's not a big deal.
Old Oct 16, 2011 | 07:45 AM
  #124
sry110's Avatar
sry110
bah....time to borrow the inch-lb. torque wrench again : (
Old May 7, 2012 | 07:37 AM
  #125
F2CMaDMaXX's Avatar
F2CMaDMaXX
Yeah, again again for me, MREV2 incoming
Old May 24, 2012 | 07:28 PM
  #126
geomark's Avatar
geomark
I just bought the mrev2 with the copper iso thermal spacer and aramid gasket for my 35th anniv revup. Will i hurt anything by going this route since i live in mostly a hot climate, Las Vegas, since the copper is mostly benefitting to a colder climate?
Old May 24, 2012 | 08:09 PM
  #127
F2CMaDMaXX's Avatar
F2CMaDMaXX
No, you won't hurt anything.
The copper advantage is that you can forget about it. The tap (manual version) is cheaper (i think) and if it got really cold, you'd want to turn it back on.
Short version, you're all set
Old Jan 4, 2013 | 02:14 PM
  #128
Tony Touch's Avatar
Tony Touch
I'm in the middle of my install now and had a quick question.... how do you remove the guide pins?
Old Jan 4, 2013 | 03:53 PM
  #129
F2CMaDMaXX's Avatar
F2CMaDMaXX
The method is in the instructions, but you basically put both nuts on the pin and then use them to undo the pin.
Old Jan 18, 2013 | 06:36 AM
  #130
Looking4myZ's Avatar
Looking4myZ
Is the MREV2 Compatible with the Non Rev Engines?
Old Jan 18, 2013 | 07:23 AM
  #131
F2CMaDMaXX's Avatar
F2CMaDMaXX
Yes it is, running it on mine
