Motordyne XYZ-Pipe (Pilot Production)
Old Jul 20, 2008 | 05:36 AM
Diesel350's Avatar
Diesel350
When will you be posting pics of your True Dual exhaust?
Old Jul 20, 2008 | 05:49 AM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
I have pics of the prototype, but the prototypes arent very picture friendly. Once they come off the production line I'll post the pics.
EDIT:
Of all the systems, there will be Single, Dual, True Dual X and 3" True Dual.
Old Jul 20, 2008 | 06:14 AM
Hydrazine's Avatar
Hydrazine
Do you have a dyno shop available that also has a lift?
Old Jul 20, 2008 | 06:21 AM
Diesel350's Avatar
Diesel350
There is one right down the street from me at S and R performance.
Old Jul 20, 2008 | 06:23 AM
_ink's Avatar
_ink
Would you be able to advise of an estimated gain with your Y pipe for someone that already has a Fujitsubo y-back exhaust?
This would be with your resonator and cat combo.
Old Jul 20, 2008 | 06:26 AM
Diesel350's Avatar
Diesel350
EDIT:
What is the difference between the Dual, and True Dual X? Does the Dual X just produce more power and different sound?
Old Jul 20, 2008 | 06:31 AM
Hydrazine's Avatar
Hydrazine
Would you like to do a pre/post dyno test?
Old Jul 20, 2008 | 06:32 AM
Chef-J's Avatar
Chef-J
Booooosstt!!
XYZ pipe, can make an exhaust sounds diff? ( with other brand exhaust system)
Old Jul 20, 2008 | 06:41 AM
Hydrazine's Avatar
Hydrazine
Like a HP comparison of Test pipes Vs aftermarket Catalytic converters, the XYZ straight pipe Vs XYZ Catalytic converter does the same. There is about a 4 HP difference.
Do you currently have test pipes?
Are you currently using the Fuji Y pipe?
Old Jul 20, 2008 | 07:10 AM
Hydrazine's Avatar
Hydrazine
When the exhaust gasses are properly merged together, it doesn't matter what happens after the merge point as long as basic pressure drop is kept in check. The single, dual and true dual all pretty much make the same amount of power.
Functionally speaking, and based on all of my dyno testing, a good single exhaust is all that is needed. But many people like the symmetrical look of a dual exhaust. And this is very understandable. So a dual is offered.
And some people want a True Dual exhaust system. So it is also offered.
There will never be one kind of exhaust system that is universally liked by everybody. Everybody has a different want, need, budget, application and sound preference.
The Motordyne exhaust system(s) are made modular and interchangable to accomodate a very wide range of applications and sounds.
If you want it very loud to very quiet, this system will let you have it from both extremes and with anything in between.
Once again, it is also easy to switch from one sound extreme to the other in less than 5-10 minutes.
For example, the rear difuser section of the Shock Wave exhaust is one "V-band" clamp away from switching out with the VQ muffler.
The Shock Wave is far from being the loudest exhaust system in the Motordyne line up, but if you are feeling like a quiet ride on your way to work, you can clamp on the VQ rear muffler section.
And if you want to raise hell over the ZdayZ weekend, you can just as easily reconect the rear diffuser section of the Shock Wave.
Two totally different sounds can be changed with only one nut on a V-band clamp to turn.
These are only two mentioned so far. There are more that will be posted.
Cannister mufflers with spiral louver core or perforated cores for different flavors of sound. Even Titanium mufflers with serious bling factor.
Titanium pics will be posted next week.
Old Jul 20, 2008 | 07:19 AM
plumpzz's Avatar
plumpzz
If you are interested in a tester for that Y pipe i'm down. I have a Jic exhaust with a standard ebay Y pipe. If you want gains over that I can help you out. MRC can do the dyno
Old Jul 20, 2008 | 07:33 AM
Hydrazine's Avatar
Hydrazine
Done.
Old Jul 20, 2008 | 07:35 AM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
Ferrari sound huh.... Well I have nismo full exhaust with test pipes and is LOUD and exotic. If u post a clip and it gives me that ferrari sound I want sign me up.
Old Jul 20, 2008 | 07:55 AM
singh's Avatar
singh
_______________
It is kind of confusing. I need to see pictures of this exhaust mounted to a Z. I was wondering if I should change my y-pipe for something that will offer more flex so they will prevent my Berk HFCs from cracking.
Old Jul 20, 2008 | 07:59 AM
Hydrazine's Avatar
Hydrazine
With a XYZ pipe and associated catalytic converter module, you can use any set of regular test pipes. Any kind of test pipe you think won't crack.
Converter problem solved.
Old Jul 20, 2008 | 08:06 AM
Hydrazine's Avatar
Hydrazine
Very good.
Would you like to dyno compare a single exhaust against the HKS?
I will be sending out a Shock Wave exhaust and XYZ pipe on tour for dyno testing.
It will be greatly discounted if you would like to keep it on your car. In any case, I'll pay for the dyno.
Give me a PM and we'll set it up.
Old Jul 20, 2008 | 08:09 AM
Hydrazine's Avatar
Hydrazine
Give me a PM and we will set it up.
You might also want to give Julian a heads up too. I don't know if he views the forums any more.
Old Jul 20, 2008 | 08:28 AM
  #38
jonnylaw's Avatar
jonnylaw
Is there a difference in having only one cat as opposed to 2 like the stock setup in "cleaning" spent exhaust gasses? (Is one just as effective as two for environental/smog concerns?)
Old Jul 20, 2008 | 08:29 AM
  #39
Diesel350's Avatar
Diesel350
Very good.
You have a PM
  #40
Hydrazine's Avatar
Hydrazine
A good question was asked over on G35driver.
Originally Posted by Da-G-SpoT
So basicaly i can leave my stock cats on, install the Y pipe, then just play around with the resonator which is like another cat? Sorry for the noob question lol
The resonator is not a catalytic converter, but yes.
You can install the XYZ and switch in or out any kind of module you like.
Even the XYZ catalytic converter.
These cars are too new to be concerned about it right now, but as they get older the stock cats will slowly wear out, lose catalytic efficency and the emissions will increase. Particularly if you have an oil burner.
If your car is on the edge of passing or failing emissions requirements... depending on what the problem is, an extra catalytic converter, in fresh condition, cleaning up the exhaust flow may just do the trick.
