Motordyne XYZ-Pipe (Pilot Production)
Old Jul 21, 2008 | 09:37 AM
  #101
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
Originally Posted by Vq.turbo.DremZ
how much did the diffuser affect the powerband in comparison to regular canister style mufflers and the ones you will be offering??
A little more than 1/2 a HP when NA.
In all of the research I've done, I've found a collection of various small increases. 1/2 a HP here, 1/2 a HP here, 1-2 HP there, a little more TQ boost on another part of the curve and so forth.
With several small increases available, why not utilize them?
Note: where the diffuser is used also makes a difference. I'll go more into this later.
I also found areas of trade. For example, the primary tubes on the collector... I experimented with 2", 2.25" and 2.5" while holding all other variables constant.
Each different diameter had its strong points, it took a little bit of a judgement call to decide the optimum here, but 2.5" primaries had the best overall curve.
2.25" was good too, but it lost 2 HP up top. 2.25" didn't really seem like an acceptable trade.
Old Jul 21, 2008 | 12:45 PM
  #102
scmtkings4's Avatar
scmtkings4
Originally Posted by Hydrazine
I wouldn't bother with it if that's all you intended to do. Its not untill you have a fully modified exhaust that it is worth considering.
Optimizing the collector merge point is a dyno subtlty that also feels good on the throttle response. Its not MREV2 like gains.
The XYZ pipe outlet is 3". The stock midpipe is 2.5".
The sudden contraction from 3" to 2.5" would likely negate any gains made.
i was going to switch out my nismo y pipe for the XYZ pipe but im gathering from this response that i shouldnt even bother with it? No sound difference?
in your first post it said that the resonator should improve the sound? But should i not bother with it if i was just gonna get the XYZ with resonator?
Old Jul 21, 2008 | 12:49 PM
  #103
rcdash's Avatar
rcdash
RCdash,
Will do.
There will be the ultimate dual FI exhaust system for the very high HP applications. This one will be saved for last.
After it comes out, it will have to be tested and compared for fitment and dyno results against all other FI exhaust systems on a very high HP Z or G.
Thanks Tony. I don't know how much hp you need to consider "very high", but I'm willing to set the PSI to whatever meets your requirement! (Either that or I'm sure I can bribe you).
Honestly, I'm tired of the loud exhaust drone while cruising around town (2k rpms) and want something quiet that still flows. No fumes + no noise + turbo power = 0 exhausts to choose from. I'm hoping someone on this planet comes up with a product to fill this empty niche...
Old Jul 21, 2008 | 01:13 PM
  #104
2004Black350z's Avatar
2004Black350z
Exhaust Whore
hmm good point. But again if I can get a more exoctic sound like a ferrari over my Nismo F it im in. unless its alot of money
Old Jul 21, 2008 | 01:28 PM
  #105
ginobetterfly's Avatar
ginobetterfly
Tony, correct me if im wrong, but i think him adding the XYZ pipe with resonator will get rid of the rasp/rattle that people experience with nismo exhaust and HFC/test pipes combo... (i know i experienced this when i had my nismo exhaust and Berk HFCs)
i think this is what tony meant when he said it will improve the sound.. to me, no rasp, is the best sound improvement there is.
Old Jul 21, 2008 | 01:29 PM
  #106
Allen331's Avatar
Allen331
I have the nismo catback with the Berk metallic HFC. As of right now, I get slight rasp and some popping, which I assume the resonator will fix. If you have a stock cats with the nismo exhaust, keep it that way...it sounds like sex.
I really liked the stock cats plus nismo catback sound, but after I added HFC, the exhaust note I was trying to keep kind of disappeared. I'm hoping this resonator will cure the slight rasp and popping.
Old Jul 21, 2008 | 01:39 PM
  #107
ginobetterfly
yeah the rasp is terrible... although i think the nismo with Berks (minus the rasp) sounds better than nismo with stock cats... the HFCs really wake it up..
i would be EXTREMELY interested in hearing the XYZ pipe w/ resonator, nismo muffler and HFCs or test pipes... according to tony, the resonator might just get rid of the rasp thats experienced even with test pipes!!
Old Jul 21, 2008 | 02:51 PM
  #108
plumpzz's Avatar
plumpzz
I'll be doing some of the testing. I have a setup that rasps, and I'll compare sounds and post data and videos when its all done with a resonator.. Just wait and see!
Old Jul 21, 2008 | 03:37 PM
  #109
singh's Avatar
singh
_______________
Yeah I noticed the popping with this setup too! It sounds pretty cool to me. HA!
There is a slight rasp, but it's there for a few hundred rpm's and then it dissappears. You guys must mean serious business for getting the exact tone you desire. I don't blame you, it's addicting.
I do however wonder if I can get rid of the hissing I hear everytime I drive the car with the windows down.
Old Jul 21, 2008 | 03:56 PM
  #110
Hydrazine's Avatar
Hydrazine
I've made a lot of posts, but I believe that quote was a response to a question relative to the XYZ pipe on a fully stock exhaust system.
I wouldn't bother putting it on an otherwise stock system.
The stock Mid pipe is 2.5". And sudden contractions in the system tend to add rasp. So connecting a resonated XYZ to a stock midpipe would be pointless.
That's a very different situation from what you have.
In your case, you have a 3" midpipe so yes, it will certaintly improve the sound.
If you have test pipes or HFC's on the Nismo exhaust, yes, the resonated XYZ will make a clear reduction in rasp.
Old Jul 22, 2008 | 07:46 AM
  #111
nothix's Avatar
nothix
have any of the independent dynos been completed yet?
Old Jul 22, 2008 | 08:06 AM
  #112
Hydrazine's Avatar
Hydrazine
No. I still need to get more parts from production to send out.
Dynos will be posted probably within hours of their completion.
...With sound and video too.
Old Jul 22, 2008 | 06:00 PM
  #113
aarantes's Avatar
aarantes
Can't wait I really want to hear the shockwave I am looking into single exhausts right now.
Old Jul 22, 2008 | 06:51 PM
  #114
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
tony, taking over the world one car part at a time.
Old Jul 22, 2008 | 09:29 PM
  #115
Glex25's Avatar
Glex25
Tony
Let me know once the Dual 3" with X pipe is released or if you need someone.
I might not be high HP(425WHP) but definitely like the way the exhaust comes apart with the V-Clamps.
Current setup:
APS TT
Fast Intentions 300cell HFC
Greddy EvoTT true dual 2.75"
Also I see your saying that with the Y pipe that you offer you can
have the cat at that location and use test pipes further up where the
stock cats go but wouldn't that in turn set off O2 CEL's since the O2
sensors would not be relocated.
Old Jul 22, 2008 | 09:43 PM
  #116
Hydrazine's Avatar
Hydrazine
Originally Posted by Glex25
Tony
Current setup:
APS TT
No. I'll have a fix for that once the MD test pipes come out.
Old Jul 23, 2008 | 01:40 AM
  #117
jammin's Avatar
jammin
motordyne is coming out with test pipes also? and is this the first part of that secret product your coming out with, with the supposed 40rwtq gain? looking forward for that piece
Old Jul 23, 2008 | 03:48 AM
  #118
FAIRLADYZ_MANnE's Avatar
FAIRLADYZ_MANnE
thats the other one, and that wont come out for awhile, so might as well forget about it, and just be suprised when it comes out.
he said, the gains are better than the orignal protoype. they are so great posting the gains might get flamed because they are so good.
Old Jul 23, 2008 | 03:56 AM
  #119
FAIRLADYZ_MANnE
Originally Posted by Fluid1
I hope you're racing on the track.
More hp usually means you're going to notice a difference in a race if you drive well.
If you're worried about what to say to other people asking about your mods, you're too juvenile for this discussion anyway.
well i hope i could amuse some people one here, but i guess not.
i should have known the type of people who drive Z's
anyway.
i guess it will just be like all the other exhaust in performance,
some people look for sound
some people look for looks
I look for power, even if its just a bit more than other exhaust systems.
hey tony, would there be any chance to throw up a dyno comparasion of stock exhaust and then yours, im pretty sure everyone on here, will believe you, mrev and spacer is gold.
Old Jul 23, 2008 | 04:21 AM
  #120
Hydrazine's Avatar
Hydrazine
Yes there will by dynos against stock. Even though I have many dynos of my own, I do prefer to let them be independant.
