APS 2.5" with TP Sounds like a honda HELP!!
Old Oct 15, 2008 | 07:19 PM
StuNyce's Avatar
StuNyce
Default APS 2.5" with TP Sounds like a honda HELP!!
I have just installed the APS 2.5" ture duel exhaust with the APS TP..
The car on revs has a rasp sound to it that sounds like a honda to me.. Does not sound clean at all.. Not sure if the muffler is bad or if it has to do with TPs??? Any input would be great thanks...
Old Oct 15, 2008 | 07:24 PM
pimpin714style's Avatar
pimpin714style
its the tp's , im not sure how the aps is setup but if its anything like the hks a x-pipe should do the trick and drop rasp.
Old Oct 15, 2008 | 07:31 PM
Webers1SlickZ's Avatar
Webers1SlickZ
Most exhaust's sound a little raspy with test pipes. Are they resonated? The only 3 exhausts in my opinion that sound good with testies are the evo2, borla, and nismo. I don't think the aps sounds that great in the first place.... so when you add test pipes it usually just makes it worse.... just an oppinion. good luck
Old Oct 15, 2008 | 07:36 PM
StuNyce's Avatar
StuNyce
The APS exhaust pipes are resonated.. The TP's are not.. When I get a chance maybe I will try with stock cats back on.. See if that helps..
Old Oct 15, 2008 | 07:38 PM
Webers1SlickZ
Yep that's what I would do.
Old Oct 15, 2008 | 07:44 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
Guessing you are not FI?
Old Oct 15, 2008 | 08:03 PM
chrisaray's Avatar
chrisaray
Some of the rasp is from the test pipes leaning the motor slightly. Correcting your fuel curve will reduce the rasp to an extent.
Old Oct 15, 2008 | 08:10 PM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
. OP ill buy ur TPs from u!!! If interested PM. Nothing is gonna make it sound better except new exhaust or HFCs
Old Oct 16, 2008 | 01:14 AM
Darkness75's Avatar
Darkness75
i used to have APS 2.5 TD with HFC the same thing RASP ,Drone and low-end lose of power ,i`v just went back to Stock Exhaust ,,,WooW i`m back in Heaven .
although rasp is there (stock exhaust+Berk HFC) but 1000000 time`s better than where i was.
P.S : there is one thing i didn`t try ,,,X-Pipe alot of good reviews how X-pipes reduces RASP .
All The Best
Old Oct 16, 2008 | 01:22 AM
350Zimo's Avatar
350Zimo
i have the APS 2.5 with fast intentions TP's. And yes mine is raspy too. It's not bad, but it is raspy.
Old Oct 16, 2008 | 01:36 AM
dozzer1b's Avatar
dozzer1b
i have that exhaust as well w/ helix TP's, very raspy, if u turbo it tho....that quiets it up real good!!!
Old Oct 16, 2008 | 05:01 AM
2004Black350z
Exhaust Whore
2.5" exhaust on built turbo
Old Oct 16, 2008 | 05:12 AM
Highway Riding's Avatar
Highway Riding
VTEC YO
Old Oct 17, 2008 | 02:31 PM
Fluid1's Avatar
Fluid1
I have the slightly smaller than 2.5" Borla exhaust on the built TT 496whp
Old Oct 22, 2008 | 12:33 PM
StuNyce's Avatar
StuNyce
I have removed the TPs... Sounds 100 times better.. thanks...
Old Oct 22, 2008 | 03:11 PM
matix101vz's Avatar
matix101vz
i have borla with res tps and it sounds exotic
Obadabot
Jun 18, 2023 11:31 PM
wanderingstuden
Jan 28, 2016 07:03 PM
Justin100
Nov 29, 2015 03:58 PM
samansharif
Sep 25, 2015 12:31 PM
