Borla Exhaust problem.. help needed!
Old Aug 31, 2003 | 03:43 PM
Ricky's Avatar
Ricky
Default Borla Exhaust problem.. help needed!
I keep getting a rattling sound from my right side, passanger area.. it sounds like a rattle.. sort of like a piece of paper hanging out the window. I feel it at lower RPMs, and when just coasting, but not at WOT. I checked the clamps and tightened them, but I seem to still have the rattle. What should I do next?
Old Aug 31, 2003 | 05:04 PM
zwindsor's Avatar
zwindsor
Twisty addict
That sounds more like an exhaust leak. When you tightened the clamps, I hope not past the recommended torque, did you notice any discoloration around any of the joints?
Old Aug 31, 2003 | 05:19 PM
CaneZMD's Avatar
CaneZMD
This might be different, but mine made a noise when I started from a stop at around 2000 rpm. It souned like it was on the passenger side too. It ended up being that the Borla bracked on the pipe just before the muffler on the left was rattling against the metal bracket that it was hanging onto on the Z. I took off the bracket and now it sounds fine.
Just a thought.
Old Aug 31, 2003 | 05:28 PM
apex locator's Avatar
apex locator
Default Re: Borla Exhaust problem.. help needed!
sounds like exhaust leak to me......but should become a little louder at WOT, unless the engine is drowning out the noise.
Old Sep 2, 2003 | 05:59 AM
insaneamine's Avatar
insaneamine
Inventor
Z-Xtreme.com
The rattle is from the hanger just before the muffler on the passenger side!!! The hanger is just behind the wheel spring.
Get under the Z and check it out, you'll see the dent from the contact.
This past Friday I complete removed the exhaust system to make sure the alignment was correct and to fix the noise. NOT RECOMMENDED!!! The removal was very difficult since the pipes had expanded and contracted to a tight fit.
I didn’t take pictures so; I’ll have to describe my fix.
With the exhaust removed I attacked the offending hanger with my trusty Dremel tool and a cutting wheel.
The main hanger body is about ¾” in thickness and then tapers down to about ¼”. I complete trimmed off the ¼” piece. Not to worry, this did not compromise the integrity of the hanger in any way, IMHO.
NO MORE RATTLE!
If I had to do it again, I would have simply unbolted the rubber bushing and then trimmed the hanger. This would have been a much easier option. I just wanted to make damn sure there were no contact points from the exhaust.
Old Sep 2, 2003 | 08:55 AM
2003z's Avatar
2003z
Thanks for the tip, Guy, I'll have to attack that when Im installing mine.
Old Sep 2, 2003 | 07:51 PM
ihiustler's Avatar
ihiustler
i had this porblem and i had the h-pipe welded and that solved the problem.
Old Sep 3, 2003 | 01:03 AM
joust75's Avatar
joust75
I had a rattling problem too.
The left pipe just forward orf the resonator was banging on the M brace. It was driving me nuts. All the piping was fitted properly and very tightly too.
Too fix we lowered the M brace about a centimeter and a half by putting washers on two of the bolts between the m brace and mounting points.
No More rattle.
Old Sep 3, 2003 | 09:18 AM
Ricky's Avatar
Ricky
Thanks guys! I'll try to play around with the hangers a little bit this weekend.
hulkout
Apr 28, 2017 09:00 PM
Justin100
Nov 29, 2015 03:58 PM
kyin
Oct 15, 2015 05:54 AM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
jsunly
Sep 19, 2015 01:22 PM
