Test pipes without bracket ?
Old Jul 6, 2009 | 12:28 PM
MontrealAtNight's Avatar
MontrealAtNight
Default Test pipes without bracket ?
I bought JVT-R Test pipes.
I went to my local exhaust shop to get it install.
Once the car was lift, the guy told me that he had to weld brackets to my test pipes to make sure they connect to the transmission support.
Total cost = 200 CAN$ ( 170 US)
Is that right or I must simply get TP's with the bracket already welded on.
If so, which brand.
Thanks.
Old Jul 6, 2009 | 01:07 PM
homErx55's Avatar
homErx55
You should have saved that guy some time by telling him not to weld on brackets..
you don't really need those.. I think I read somewhere that said the bracket eventually puts more stress onto the pipes+headers somehow.. lol
Old Jul 6, 2009 | 01:41 PM
Yes. Test pipes are available with support brackets. The bracket mounts to the same location as the OEM catalytic converter.
Old Jul 6, 2009 | 01:58 PM
tylerxfire's Avatar
tylerxfire
some have them some dont...they are designed the way they are for a reason imo..
Old Jul 6, 2009 | 03:44 PM
MontrealAtNight
which brands has brackets ? besides Helix
Old Jul 6, 2009 | 03:48 PM
DemitriHKS's Avatar
DemitriHKS
I have Ichiba pipes and they didn't have a bracket. At my dealer the GTR tech helped me on the side with the install cause he couldn't do it there and he said I actually don't need it. He didn't say it was better for more or less stress but the stock pipes need it for the extra weight. These pipes were so light that they don't.
Old Jul 6, 2009 | 04:40 PM
diablox1's Avatar
diablox1
my stillen hfcs ('07 Z) dont have them; they're not needed.
Old Jul 7, 2009 | 04:08 AM
MontrealAtNight
How long did it take to you guys to install them. The shop is billing me 2 hours. Are they retarded ?
Old Jul 7, 2009 | 08:24 AM
tylerxfire's Avatar
tylerxfire
id say realistically it is more of a hour to hour and half job, but most shops would prolly tell u 2 hours to uninstall the stock ones and then put the new ones on..
Old Jul 11, 2009 | 10:41 AM
Sequence's Avatar
Sequence
i had Titek test pipes installed to my Nismo catback. charged like $75 at midas(taxes in). shouldn't take more than 30-45 min. 2 hrs?...ur getting owned. i'd call them on it.
Old Jul 11, 2009 | 10:42 AM
Sequence's Avatar
Sequence
.... as far as the brackets... i have them on my Titeks and they cracked and so did my flange at the rear section... i'm assuming it's because of the stress from that bracket. you shouldn't need it....i'd say better/safer without
Old Jul 11, 2009 | 10:48 AM
Nismospeed4life's Avatar
Nismospeed4life
My Kinetix Test Pipes only weigh 10lbs combine, as supposed to 35lbs combine by the OEM CATS. I say the only reason that the OEM CATS came with brace support is because they were so damn heavy to begin with. No need for brackets on TP's IMO.
*Unless you have a Nismo exhaust, then they will get cracked no matter what.
Old Jul 11, 2009 | 10:58 AM
Sequence's Avatar
Sequence
Originally Posted by Nismospeed4life
My Kinetix Test Pipes only weigh 10lbs combine, as supposed to 35lbs combine by the OEM CATS. I say theo only reason that the OEM CATS came with brace support is because they were so damn heavy to begin with. No need for brackets on TP's IMO.
lol, yup, mine just cracked at the bracket....time for a new y-pipe or swap out exhaust...still unsure
Old Jul 11, 2009 | 11:11 AM
Nismospeed4life
Personally, I have an HK$. However, I believe Motordyne to have the best sound that I have ever heard on a exhaust!
Old Jul 11, 2009 | 12:00 PM
binder's Avatar
binder
I have jvt. Once i had mine installed i welded a small bracket to them after i bolted the bracket to the original brace.
I doubt it's needed but it didn't take me an extra 10 minutes to add that to it.
Did yours line up? mine didn't line up at all and i had to modify my borla cat back exhaust big time to get those test pipes in there. The rear o2 sensors pointed partially down and i had to weld new o2 bungs pointing slightly up so they would'nt drag the ground. I guess they were cheap for a reason.
sales@czp
Sep 23, 2019 03:30 PM
issyz
Jul 2, 2017 03:04 PM
codek
Sep 28, 2015 03:03 AM
