Need help for high flow cats install
Old Aug 6, 2009 | 11:43 AM
cedoulinou's Avatar
cedoulinou
Default Need help for high flow cats install
I'm going to install my new berk hfc tomorow and I want to know if you guys have some tricks to remove it the oem cat...
How to remove the three bolts that fix it to the header???
thanks
Old Aug 6, 2009 | 12:13 PM
skingy's Avatar
skingy
a loooong extension and universal - and get to them from the engine bay. well, the top bolts - the other 2 can be had from under the car.
Old Aug 6, 2009 | 12:27 PM
s31t8n8's Avatar
s31t8n8
soak the bolts with PB blaster overnight so they come off easier.
Old Aug 6, 2009 | 12:28 PM
CancerJCCz's Avatar
CancerJCCz
This.
And IBtylerxfire says you don't need to do it from the top.
And also may want to just get new gaskets the first time around. (I did not and had leaks so it was basically the same job twice)
Old Aug 6, 2009 | 12:41 PM
06Enthusiast's Avatar
06Enthusiast
Here's an excellent how-to video: http://www.youtube.com/watch?v=bH9irOK9sdo
Old Aug 6, 2009 | 12:49 PM
tylerxfire's Avatar
tylerxfire
yup i do them from the bottom and have done them 3 times now and a 4th next week...my berks failed twice so i gutted them out and now they are cracking so berk is replacing them with their test pipes and ill be swapping again...i do them all from the bottom and there is only 1 bolt that is fixed to the header the others come out..just do it and get a bunch of different extensions and some bars to extend ur ratchet for more leverage is what i do.. u will need a deep 14 and a normal size 14 mm socket and a few different extensions to play with..16mm wrench i beleive it is also
Old Aug 6, 2009 | 02:23 PM
Thumbs up
Hints: Spray all hardware with penetrating spray the night before.
Old Aug 11, 2009 | 09:25 PM
JJR4884's Avatar
JJR4884
ya, do the driver's side first.... i just helped a friend out tonight... the top bolt is blocked a little by the steering shaft/column.... if you can get that off, the rest will be a walk in the park
guess which one we did last
Old Aug 12, 2009 | 06:03 AM
tylerxfire's Avatar
tylerxfire
def. do driver side first and get it out of the way...also remove the bar that goes across and bolts to both cats brackets u will have more room...i just changed my high flows out for test pipes yesterday once again..toook about 45 mins. start to finish
Old Aug 12, 2009 | 06:11 AM
SRT8-Jeep's Avatar
SRT8-Jeep
you can also heat the studs with a torch to crack the rust off of them
Old Aug 12, 2009 | 04:53 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
Are you still under there OP?
Old Aug 12, 2009 | 10:43 PM
cedoulinou's Avatar
cedoulinou
thanks guys it's done since yesterday lol
according to me the best way to unscrew the bolt facing the engine bay have been to pass by the engine bay with a long long long extension like Skingy said the others bolt were very easy to remove... <
thanks again to all of you for your help
AbrasiveRaysive
Sep 20, 2021 02:29 PM
