"That metal clanging sound"
Old Aug 28, 2009 | 07:20 AM
eNdiT's Avatar
eNdiT
Default "That metal clanging sound"
Does anyone else have that metallic clanging/shaking sound when they accelerate or let RPMs fall slowly? I notice it alot at low speeds and it's loud as hell when you drive by another car or a wall/median on the road. It sounds like a tin can and it's hard to ignore.
I really want to know how to get rid of this sound without overhauling any systems completely. Does anyone know what actually causes this noise?
Thanks
Old Aug 28, 2009 | 07:27 AM
rcdash's Avatar
rcdash
Exhaust hitting the rear sway bar? You really need to provide more detail on your car's mods to get any sort of answer...
Old Aug 28, 2009 | 08:19 AM
anyjuan's Avatar
anyjuan
Do you have test pipes?
Old Aug 28, 2009 | 08:56 AM
eNdiT's Avatar
eNdiT
I have a stock 350Z as far as exhaust goes, so I'm not sure what would be causing this noise...
Old Aug 28, 2009 | 09:56 AM
Brrcats's Avatar
Brrcats
improperly secured exhaust hitting the lower arm of the left rear tire?
Old Aug 28, 2009 | 10:58 AM
anyjuan's Avatar
anyjuan
^ had that very issue on my previous car. Should be an easy fix.
Old Aug 28, 2009 | 11:32 AM
Manjot's Avatar
Manjot
Is it a rattling/poping sound? Are you running TPs or HFCs?
Old Aug 28, 2009 | 12:43 PM
VO...'s Avatar
VO...
Administrator
Never heard that sound before on my Z...
Old Aug 28, 2009 | 02:16 PM
DallasZ33's Avatar
DallasZ33
Check your undertray, thats what my metal clang came from..
Old Aug 28, 2009 | 09:12 PM
lasvegas350z's Avatar
lasvegas350z
i have the same thing since i put my borla on...it only happens when the exhaust is hot and at low rpms
Old Aug 29, 2009 | 09:44 AM
kyle22's Avatar
kyle22
i had that for a day then it went away the next..if possible put it on a lift and check for clearance issues.
Old Aug 29, 2009 | 11:16 AM
Toby-22's Avatar
Toby-22
mine happens when i deaccelerate at low gears. Sounds like a rattlesnake like wat others have said. I think mine is rasp tho
Old Sep 16, 2009 | 04:27 PM
SniperHunter's Avatar
SniperHunter
Thanks
Check to see if your exhaust is hitting either the sway bar in the rear, or the EVAP canister (little black metallic square box by the arm of the exhaust right before the muffler).
etkms
Jun 19, 2022 06:30 PM
Soma
Sep 10, 2002 06:49 PM
blueshift
Aug 14, 2002 08:01 AM
