Hydrolock...
Old Feb 19, 2010 | 08:42 AM
BJJ Gi Choke's Avatar
BJJ Gi Choke
Default Hydrolock...
It's been raining like crazy in CA lately and it made me start thinking about Hydrolocking.
So I just got the K&N Typhoon Cold Air Intake (good deal on ebay)
Do you guys think this intake is safe as far as Hydrolocking?
The thing is, this pipe is actually 2 pipes so the snorkel is just feeding the air box with colder air from outside.
What has been your experience (for those that have it)?
If you look on this page it says that this design does not allow for chance of ingestion of water causing hydro-lock.
Old Feb 19, 2010 | 08:43 AM
Entaille's Avatar
Entaille
if you submerge the car under water and the tube sucks up water, it's a possibility.
Old Feb 19, 2010 | 08:48 AM
BJJ Gi Choke
I'm thinking that the tube is not sucking (its not connected to the intake), it's only having air push in rather than pulled in. If that makes any sense.
Also what if you cut holes in the bottom of the air box so if water does make it all the way in, it has a way out...
Old Feb 19, 2010 | 10:08 AM
F34RL355's Avatar
F34RL355
if the filter is in an inclosed box by the looks of it, then the engine is sucking air from the plenum and this suction transfers thru the plenum to the snorkel, so the snorkel is sucking as well.. sure there are losses and its not sucking as much but its still sucking
Z04's Avatar
Z04
please search since this subject has been discussed numerous times since 2003. plus if you are so worried about it then cancel your order on the intake and leave the OEM one on
Old Feb 19, 2010 | 10:11 AM
F34RL355's Avatar
F34RL355
Last edited by F34RL355; Feb 19, 2010 at 11:27 AM. Reason: double post thought first one was deleted
Old Feb 19, 2010 | 10:35 AM
TheFarmer's Avatar
TheFarmer
No intake is immune. Even the stock system can suck in water. Just be smart in how you drive.
Old Feb 19, 2010 | 10:43 AM
BJJ Gi Choke
I never said I was worried about it.
I'm trying to make it safer, thats all...
I knew someone would say "just don't get it" lol
It's just a matter of making things better/safer.
Old Feb 19, 2010 | 10:46 AM
Moncada90's Avatar
Moncada90
i have the same intake! you wont have a problem with the extension tube! the only chance for hydrolocking your car is if you submerge the car and the water reaches the filter, that extension tube is no problem.....
Old Feb 19, 2010 | 12:32 PM
VO...'s Avatar
VO...
Administrator
Moved...
Old Feb 19, 2010 | 01:56 PM
BJJ Gi Choke
Every thread I do gets moved.
Isnt this a general topic? Hydrolock
Old Feb 19, 2010 | 02:58 PM
zrzly?'s Avatar
zrzly?
you asked about hydrolock regaurding a certain intake system, hence the movement to the proper subforum. just buy the intake lolz.
Old Feb 19, 2010 | 03:01 PM
I installed the intake in 2004. Did plenty of write ups and photos. Search is your friend.
Old Feb 19, 2010 | 03:29 PM
Guilty1s's Avatar
Guilty1s
Have you ever tried using a snorkel upsidedown?
Old Feb 20, 2010 | 06:58 AM
3-fifty-WeEe's Avatar
3-fifty-WeEe
^^ good thinking, put the snorkel up the pillar on the outside of the car like the Jays racing snorkel for the toyota mr2
Old Feb 20, 2010 | 06:59 AM
3-fifty-WeEe
or you could weld a tin can onto the top of your plenum for a velocity stack!!
doomsdaydonkey
Jan 6, 2010 02:05 AM
