The INFAMOUS "Hissing" or rattle coming from the 07+'s
Old Mar 19, 2010 | 06:45 AM
NY350zG's Avatar
NY350zG
Default The INFAMOUS "Hissing" or rattle coming from the 07+'s
Okay so FINALLY after an awful winter here in NY... My Z is officially back on the road. I own a 2008 and its been in storage for the whole winter pretty much. The past couple of days i have been looking at my exhaust set up and wondering why my exhaust would be making a noise which really almost sounds identical to a "rattle snake".. It only makes the noise when im off the throttle and the rpms reach about 2300rpms till about 1400rpms...
My current set up is 2.5 inch GTM (non resonated test pipes) to the stock Y to a Tanabe Medallion Cat back system. My thoughts originally were that the noise was coming from the stock Y and the flex pipes in the Y... ANYONE have a resolution or this similar problem?
Old Mar 19, 2010 | 06:52 AM
brandon3434's Avatar
brandon3434
edit* sorry, different issue.
Old Mar 19, 2010 | 07:05 AM
Phenom's Avatar
Phenom
Toasty
Mine started doing it as soon as my berk tp's went in. Pretty sure that's just the sound they make. Nothing wrong.
Old Mar 19, 2010 | 07:09 AM
0jiggy0's Avatar
0jiggy0
Its rasp. Nothing you can do besides go with resonated tps or HFCs.
As has been explained WELL over a dozen times.
Old Mar 19, 2010 | 07:11 AM
Ronin82's Avatar
Ronin82
could be and sounds like the Cats or possibly one of the hooks in that hold up your exhaust
I think the hissing sound is normal. I hear it when I rev it and it hisses when the rpm's are dropping. Its really heard usually after an aftermarket exhaust goes on
Old Mar 19, 2010 | 08:33 AM
zerostyle's Avatar
zerostyle
yeah i get hiss and then the vib/rattle when the rpm's decel to about 2500
Old Mar 19, 2010 | 08:50 AM
diablox1's Avatar
diablox1
normal
Old Mar 19, 2010 | 09:29 AM
Guilty1s's Avatar
Guilty1s
Mine does it... TPed and TD
Old Mar 19, 2010 | 09:33 AM
kramykram's Avatar
kramykram
order a stillen ypipe if you think its the flex joints. or put the stock cats and exhaust on and see if it is still there. if it is replace under warranty
Old Mar 19, 2010 | 10:17 AM
zerostyle's Avatar
zerostyle
yeah i know its the tp's. but actually now that you say that. its not the first time i hear that...changing out the y pipe...i guess ima just have to try it.
Old Mar 19, 2010 | 10:22 AM
Ronin82's Avatar
Ronin82
the rattling I had and it turned out to be just a hook. The big rubber grommets that hold the hooks can usually just be adjusted.
Old Mar 19, 2010 | 12:37 PM
Phenom's Avatar
Phenom
Toasty
I think this concern can be laid to rest. It seems like every car 07, with any brand of non-resonated test pipes, with any aftermarket exhaust, makes this sound at the same throttle position at roughly the same rpm range.
Just think of it as the sound of freed up POWAH.
Or a rattle snake slithered up all of our exhaust tips
Old Mar 19, 2010 | 01:08 PM
Ronin82's Avatar
Ronin82
Theres a tiny snake in the rivers of S. America that does the same but up your *****!!!!
Old Mar 19, 2010 | 08:58 PM
zerostyle's Avatar
zerostyle
yeah but mine are resonated. and it still does it...
Old Mar 20, 2010 | 06:23 AM
blue350zed's Avatar
blue350zed
Never noticed it, maybe I got lucky...
Old Mar 21, 2010 | 04:20 AM
kramykram's Avatar
kramykram
i never had it either with test pipes or high flow cats. just waiting on these damn art pipes for the hr to come out.
Old Mar 22, 2010 | 06:54 AM
BoomerZ33's Avatar
BoomerZ33
Just installed berk hfc's over the weekend and i too started hearing the hiss sound during deceleration. if it's something common that alot people hear then i won't worry about it too much. i'll just turn my music a lil louder
Old Mar 23, 2010 | 04:24 PM
AmorZ_Fati's Avatar
AmorZ_Fati
Mine to w/ an 05
Old Mar 25, 2010 | 07:25 AM
rich2342's Avatar
rich2342
op,
Mine is a DE, but I have Berks + HR-y-pipe and Tanabe which does have the hiss on hard accelleration and on Decelleration.
I can't put my finger on it, but probably due to the different piping diameters of each connection point.
I'm curious if a resonated XYZ Pipe will do the trick as it is also excessively loud and drones horribly.
Obadabot
Jun 18, 2023 11:31 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
samansharif
Sep 25, 2015 12:31 PM
