How do you quiet interior sound from exhaust?
Old Apr 19, 2010 | 04:20 AM
kramykram's Avatar
kramykram
Originally Posted by insane350
Like the guy above said, ART pipes would help to reduce that drone. On my 00 Celica GT-S the exhaust was 2.5 straight pipe and was extremely loud. To quiet it down, I used Fatmat(dynamat knockoff) and it quieted it down a good bit. I basically did the trunk floor and the floor of the interior under the seats. It really isn't all that heavy for what people say it is, nothing that really matters or affects anything and it will reduce cabin noise
ehh kazuma???
Old Apr 19, 2010 | 04:22 AM
kramykram's Avatar
kramykram
are you running test pipes or high flows?? if so put stock cats back on that will help a lot.
Old Apr 19, 2010 | 04:58 AM
zmedic13's Avatar
zmedic13
I just have stock cats. Thanks for the input guys. I'll call Tony and ask him about the V2/Gamma set up.
Old Apr 19, 2010 | 05:51 AM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
The V2 axleback section = No drone.
Old Apr 19, 2010 | 07:38 AM
VO...'s Avatar
VO...
Administrator
Originally Posted by davidv
You are trying to solve a problem that you created. Put the OEM exhaust back on the car. Or live with it.
I'm going to have to agree with David here.
Since the OP already has the exhaust and is just trying to cope with/tone down the cabin noise and doesn't care about weight, I'd say go with the sound deadening route. I used a combo of Dynamat and spray-in bedliner for my entire vehicle. This was for audio purposes, but it also helped reduced interior rattle, keep my tunes inside the car, and reduce some road noise. You can literally be in the car with the windows rolled up and the system blasting(2000 Watts RMS), and barely hear it outside. When you close the doors, it's a solid thud instead of a clank followed by rattle. But that's my preference. I could care less about weight, even though I compensated for the extra weight by buying the Full titanium Ti Fujitsubo exhaust which only weighs 26 lbs total...
Old Apr 19, 2010 | 07:50 AM
mysmokenz's Avatar
mysmokenz
I wrapped the whole back of my car in Dynamat from the inside of the Cavity behind the seats, all the way to the very back of the car. Road noise is way down and exhaust noise is way down. I have Long tube headers, no cats, and a Borla dual exhaust.
Old Apr 19, 2010 | 07:51 AM
zmedic13's Avatar
zmedic13
I'm not going to put stock exhaust back on I really like the one I have a lot. Just want to turn down in cabin noise a bit. Its nit an allthe time drone just at speeds/rpms. I'm sure after it breaks in a little bit more it'll be better too.
Old Apr 19, 2010 | 08:53 AM
o2sys's Avatar
o2sys
adding bit of sound deadning does not add that much weight. Maybe 20~30 LBS or 50+ if you go all out.
Plus you are laying the weight out flat and distributed evenly so is not like adding a 50 LBS bag of sand in the trunk.
Go ahead with the sound deadning stuff. Start out in the obvious areas, nearest of the trunk to the muffler, then rear wheel wells, then under the seat and so on and on until you feel its tolerable.
I did almost the entire car in my STI in 1 day...
Old Apr 21, 2010 | 06:22 PM
yankeefanzh's Avatar
yankeefanzh
hey zmedic i understand where your coming from i hate interior exhaust noise too i layered my rear hatch with some dynomat knockoff and it made a noticeable difference with exhaust. if weight is not an issue then go with the sound deadening route. also got some sound deadening spray and shot the underside of my wheelwells too made a big difference.
Obadabot
Jun 18, 2023 11:31 PM
sales@czp
Sep 23, 2019 03:30 PM
Justin100
Nov 29, 2015 03:58 PM
