Got test pipes/hfc's on your HR? Post in here.
Old Sep 7, 2012 | 10:03 AM
  #221
tkuntz's Avatar
tkuntz
Originally Posted by joshie3.5.0.z
anyone know if these will fit an 08 hr? these came off a 04 z
https://my350z.com/forum/socal-marke...ght-pipes.html
unfortunatly no, you need test pipes that fit the 370z if you have an 07-08 350z.
Old Sep 7, 2012 | 10:16 AM
  #222
joshie3.5.0.z's Avatar
joshie3.5.0.z
dang that sucks this is a pretty good deal
Old Sep 19, 2012 | 08:10 PM
  #223
ModBargains's Avatar
ModBargains
Vendor - Former Vendor
The berk test pipe sounds amazing with stock exhaust
Old Sep 19, 2012 | 10:59 PM
  #224
supanam's Avatar
supanam
tkuntz is right... the 04 header flange is different than the 07/08 header flanges
Old Sep 20, 2012 | 03:52 PM
  #225
CLyons0203's Avatar
CLyons0203
are you guys using the oem o-ring gasket? Are you pushing it into the oem header? I dont see how the oring will sit on the flat flange of a HFC or test pipe
Old Sep 25, 2012 | 07:13 AM
  #226
kramykram's Avatar
kramykram
Berk makes a very nice graphite gasket for this.
Old Sep 25, 2012 | 09:25 AM
  #227
kno's Avatar
kno
full motordyne v1 exhaust
Old Sep 26, 2012 | 05:40 PM
  #228
CLyons0203's Avatar
CLyons0203
didnt answer my question an dmy Berk gaskets are leaking.
Old Oct 12, 2012 | 05:52 AM
  #229
kramykram's Avatar
kramykram
you can't use the stock oring gasket. if you are that is why you are leaking. which test pipes or high flow cats are you using?
Old Oct 12, 2012 | 06:08 AM
  #230
kramykram's Avatar
kramykram
i appologize if this question has been already answered, but...
i have bought a set of Invidia test pipes for my 07 nismo, and i have heard that the engine light will eventually come on... what kinda of solution is there to avoid this? i am unsure as to what to do when i get them installed or what to ask them to do.. if anyone could help me out with this that would be much appreciated, thanks.
stuffing with steel whole will fix this problem. i have had high flow cats off and on and had them over a year and a half now. i stuffed one time and had not needed to restuff since. it usually rusts out. idk if my ecu just learned over time but i have had no cel at all and very happy.
Old Oct 12, 2012 | 06:12 AM
  #231
kramykram's Avatar
kramykram
Originally Posted by Tag009
Anyone favoring a certain HFC or test pipes with the borla exhaust?
Im about to go with Berk HFC, but im not sure if the sound difference will be worth the money or if i should just go with test pipes.
i am pulling my borla off today and going back with fujitsubo. i hate the sund of borla even with high flow cats its to quite. i thought about the magnaflow route but if its quite now this will by far make it even more quite. i loved the sound of my fuji and never shoulf of gotten rid of it.
Old Oct 27, 2012 | 07:52 PM
  #232
c.becker0130's Avatar
c.becker0130
Just picked up a set of Z1 HFCs and have an Ark Grip CBE, only my Nismo CAI is installed right now. I'll get an Uprev tune when I install them and a re dyno to see the numbers. I'll be sure to post that up when its done.
Old Oct 27, 2012 | 07:53 PM
  #233
c.becker0130
Default Borla
I've got a buddy with a BMW 335i, also with a Borla, its more on the mellow side, I agree with ya. Too quiet for a $1000+ exhaust
Old Dec 14, 2012 | 03:02 AM
  #234
babb's Avatar
babb
I've got an 08 with aam test pipes and the aam single catback. Definitely LOUD but other than the rasp from 2000-2500 it sounds mean. Thinking about the resonated xyz pipe to clean it up but definitely wanting to get intakes and a tune asap because the TPs definitely make it run lean. Hoping I'll have some time to post a video when I go home for Christmas.
Old Dec 14, 2012 | 03:07 AM
  #235
babb's Avatar
babb
Also forgot to mention I've had the TPs for about 1000 miles. No cracks or issues. I heat wrapped them with DEI titanium wrap which even reduced the rasp a little. Did throw a CEL which turns off occasionally.
*edit: noob just discovered the edit button. my bad on two posts in a row
Old Aug 10, 2015 | 02:22 PM
  #236
frankr224's Avatar
frankr224
i just installed berk test pipes with my stock exhaust and i love them!!
Old Aug 11, 2015 | 10:39 AM
  #237
SQuaLZ's Avatar
SQuaLZ
5 year old thread...
Old Aug 11, 2015 | 11:05 AM
  #238
PP08HR's Avatar
PP08HR
At least he didn't repost lol...
I'm glad this was resurrected. I want to get TP soon and just read all of these.
Old Aug 11, 2015 | 11:18 AM
  #239
travlee's Avatar
travlee
Master
go big or go home... ART pipes
issyz
Jul 2, 2017 03:04 PM
