Got test pipes/hfc's on your HR? Post in here.
Old Oct 5, 2010 | 11:47 AM
  #141
tribal_visionz's Avatar
tribal_visionz
I thought someone got the CEL light with the ART tp's. Check the thread, he also drives an HR. Hydrazine, I think his name is, said that he was the first one to trigger the CEL light. He also mentioned a resolution, this was posted at midnight.
Old Oct 5, 2010 | 02:35 PM
  #142
ChrisNI's Avatar
ChrisNI
Just bought myself some Kinetix HFC's from Mike CZP on here ... Great price and look to be 100% quality ... cant wait to get them fitted ...
Old Oct 23, 2010 | 05:49 PM
  #143
SE5spd's Avatar
SE5spd
quick question
im ordering test pipes on monday from Kyle(Houston) (thats his username, not sure what company he works for or owns) hes selling AAM test pipes for $265.00 shipped plus id have to spend $25.00 on the collector gaskets, or berk test pipes for $275.00 shipped so the AAM are 290 and the berk are 275, basically the same price and I CAN NOT DECIDE WHICH TO ORDER!!!!!!!!!
any input or help would be much appreciated
Old Oct 26, 2010 | 11:25 PM
  #144
Frostydc4's Avatar
Frostydc4
^^^ They essentially perform the same. I would go with what ever is cheaper IMO
Old Oct 27, 2010 | 09:59 PM
  #145
SE5spd's Avatar
SE5spd
I ended up getting berk cause they come with the gaskets and everything already
Old Oct 28, 2010 | 07:08 AM
  #146
srsairbags's Avatar
srsairbags
i have berks HFC in my otherwise stock setup and i love them except for the metal ringing sound / whistling soung you get after 4500 rpm . . any way to fix that ?
Old Oct 28, 2010 | 10:32 AM
  #147
karletto66's Avatar
karletto66
I have Berk HFC on my 2009 350Z HR and sound is GREAT (all other exaust is stock)
Very "aggressive" and not so loud.
No CEL also with stock ecu (now i have UPREV tune, so no CEL for ever i hope...)
Old Oct 28, 2010 | 11:01 PM
  #148
Q8y_drifter's Avatar
Q8y_drifter
Invidia HFC's here.
Old Mar 14, 2011 | 08:40 PM
  #149
KingBaby's Avatar
KingBaby
Hardest Setting
I have AAM test pipes/AAM y-pipe/stock mid-pipe/stock muffler
did any of you guys do the install yourself?
I had a question about the stock o-ring at the headers outlet did you guys remove it?
Cause I had unbearable rasp/buzzing/metallic noise. I had a shop put my mid-pipe resonator back in cause I removed it. Now it's Great with a little sting at 3.2krpm.
Anyone!
HELP with the o-ring ordeal...
I'm thinking about going with the AAM 3inch single to finish it up.
Old Mar 15, 2011 | 10:37 AM
  #150
srsairbags's Avatar
srsairbags
. . i read like 09 350z ? im like WTF ? then i see you in Italy . . awwww . . .youre good
Old Mar 15, 2011 | 02:25 PM
  #151
nismonian's Avatar
nismonian
i have art pipes, aam ypipe and an ap single on my HR. very loud! pretty deep and barely any rasp FTW
my ypipe sags a little and when i let off theres a noticeable hissing noise, is that normal? checked for exhaust leaks but couldnt find any.
Old Mar 15, 2011 | 03:22 PM
  #152
KingBaby's Avatar
KingBaby
Hardest Setting
video clips?
Old Mar 15, 2011 | 03:40 PM
  #153
nismonian's Avatar
nismonian
just this chitty clip i took a couple weeks back. i'll take a better vid soon.
http://www.youtube.com/watch?v=Mi0ONX3n44o
Old Mar 16, 2011 | 12:08 PM
  #154
srsairbags's Avatar
srsairbags
is that hissing or a metal ringing kind of whistling sound . . . ? pretty common on BERK hfcs
Old Mar 17, 2011 | 07:23 AM
  #155
Patsfan83's Avatar
Patsfan83
sounds good nismonian!!
Old Mar 17, 2011 | 01:16 PM
  #156
nismonian's Avatar
nismonian
there's a slight kinda metallic sound on accel but on decel there's a noticeable hiising sound, checked for exhaust leaks and found nothing so i guess it's the art pipes thats causing this
thanks! sounds 100x better in person.
Old Mar 30, 2011 | 12:30 PM
  #157
AadosX's Avatar
AadosX
To you guys with Berk TP's, can you reuse the stock gaskets?
Old Mar 30, 2011 | 01:58 PM
  #158
kramykram's Avatar
kramykram
yes you can, i have reused mine a few times. i ordered a new set and didn't even need. just depends on how bad they stick. luckily both of mine stuck to one side of the flange.
Old Apr 10, 2011 | 02:57 PM
  #159
kabro91's Avatar
kabro91
yea i tried to get OEM ones when I put my GTM TPs in but the turrible turrible knucklehead at ACME NISSAN (SOUTH BRUNSWICK NJ...NEVER GO THERE) ordered me the DE gaskets even though I confirmed multiple times if these fit a VQ35HR...Long story short, I reused the gaskets and had no leaks or rasp or any ill consequences
Old Apr 10, 2011 | 08:48 PM
  #160
Amirs350z's Avatar
Amirs350z
Stillen HFC's at 9.5k miles so far, so good. *crosses fingers*
