deciding on intake systems for 05!!!
Old Dec 14, 2010 | 08:27 PM
1badsterling05z's Avatar
1badsterling05z
Default deciding on intake systems for 05!!!
Sup eveyone new z owner here and first real post.im having a hard time deciding on intakes. I know bigger is better,heat shield keeps hot air out,and if going in fender bypass valve is a good idea. But what about stuff like is a longer intake tube or bypass valve gonna rob performance,can one be too big,where can i get an affordable heat shield/box,is a cold air advised for n/a motors or short ram(and is the MAF gonna be straight). Any suggestions and im one of those who tries to find the most affordable but also best in reliability and performance.help!
Old Dec 14, 2010 | 08:29 PM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
im n a GREAT mood. Samco hose JWT pocharger and make your own Heatsoak shield
Old Dec 14, 2010 | 10:50 PM
ImWeeZzel's Avatar
ImWeeZzel
wow, he is in a good mood, most peeps wouldve bashed you for not searching...
Old Dec 15, 2010 | 06:04 AM
R3belzBRN's Avatar
R3belzBRN
he is one lucky guy. lols
Old Dec 15, 2010 | 12:30 PM
terrasmak's Avatar
Popcharger , and the Samco hose to make it look pretty. Doubt the hose helps, but it looks cool.
Old Dec 15, 2010 | 01:03 PM
silvertouringz's Avatar
silvertouringz
JWT pop charger, dont waste ur time and money on anything else
Old Dec 15, 2010 | 08:44 PM
1badsterling05z
yea i was going for the jwt pop charger or the stillen from mynismo that comes with a heat sheild. Both are reasonable too. And thanks for not bashing i was just having a hard time deciding on one by the way what does pop charger even mean im curious
Old Dec 15, 2010 | 08:57 PM
Welcome.
You will see several types of intakes:
a. Replacement OEM filter. Washable is good. Lasts forever. Easy to clean.
b. Short intake. Filter under hood on the end of a tube. Easy to clean.
c. Long intake. Generally filter is behind front bumper. Pain in the *** to clean.
d. Hybrid cold air - short tube. K&N Typhoon for example. Filter in engine bay for easy access. Fresh air from behind grill.
Old Dec 15, 2010 | 09:18 PM
The Pop Charger has been a proven winner for 7 years because of its simplicity. Simple is good.
Old Dec 16, 2010 | 03:10 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
simple - just depends on what your end goals are
you are not going to get dramatic power/response/temperature changes with an intake on this car. The stock setup is quite efficient
a stock 06 airbox, your choice of filter and be done with it, is a nice simple setup, looks stock, works great
of all the mods you do, the intake system you choose, on this car is the least important, and of the least consequence
Cold airs work well for track oriented cars that end up generating alot of engine heat soak. Short rams, whether they have a heat shield or not, don't work as efficiently, but are cheaper and easier to service as mentioned
Some intakes look cooler than others...all depends on what you're buying the intake for
The Samco hose is a nice piece to dress things up
Old Dec 16, 2010 | 09:39 AM
1badsterling05z
thanks evryone but one more thing. Will a longer intake tube decrease response or power or even be noticeable. will be taking to a tracks and shows every couple months too
Old Dec 16, 2010 | 12:12 PM
terrasmak's Avatar
That funny, my JWT runs 8 degrees over the listed ambient temp (on my display) when on the racetrack. So much for HeatSoak.
Standard popcharger with standard heat shield , nothing changed from how JWT send mails it out.
Old Dec 16, 2010 | 04:03 PM
Z1 Performance
Former Sponsor
I'd have to see logs to honestly believe that...and I sell popchargers fwiw, so it's not like I have something to gain by saying what I said.
Old Dec 16, 2010 | 04:05 PM
Z1 Performance
Former Sponsor
as long as you're not changing where the MAF is located, I can't think of how response would be affected
sales@czp
Sep 23, 2019 03:30 PM
Justin100
Nov 29, 2015 03:58 PM
nanotech
Oct 2, 2015 05:02 AM
