Test Pipe without Heatshield?
Old Jan 13, 2011 | 09:54 PM
Shawz1102's Avatar
Shawz1102
Default Test Pipe without Heatshield?
Is it safe to have test pipes without heat shield? It's currently rattling against the heat shield and if i can't get it to fix i'm just going to take off the heat shield.
For those without heat shields and test pipes, can you please chime in?
Old Jan 14, 2011 | 04:48 AM
08panna's Avatar
08panna
i dont see why not. mine did not come with heat shields so i would say your good to go
Old Jan 14, 2011 | 08:03 AM
It’s safe unless the floor of your car catches on fire.
Old Jan 19, 2011 | 11:28 AM
Nizmo0395's Avatar
Nizmo0395
The converter is what heats up,thats how it works by heat.Test tubes have no restriction to collect and hold the heat from the exhaust.
Old Jan 19, 2011 | 12:30 PM
Shawz1102's Avatar
Shawz1102
Does this post danger for cars with the MD XYZ pipe with the HFC?
Old Jan 19, 2011 | 12:52 PM
jmahad01's Avatar
jmahad01
Take a screwdriver and bend it up a little. It isn't that hard and worked for me.
Old Jan 19, 2011 | 04:15 PM
Nizmo0395's Avatar
Nizmo0395
Do you have test pipes no (catalytic converter) or high flow converters?
Safe thing to do if your worried about it, another way is to use a self tapping screws and tighten up shield,don't tap into the pipe!
Old Jan 20, 2011 | 10:36 AM
BoomerZ33's Avatar
BoomerZ33
Even if you bend it back it could go back to the original position unless its secured with a screw or something. I say just remove it you'll be fine.
Old Jan 20, 2011 | 12:09 PM
Shawz1102's Avatar
Shawz1102
Well i just used a hammer and bent the heatshield, no rattles now...
i have art pipes with xyz pipe + hfc. since the converter is the one heating up, would the around around the hfc part of the xyz pipe be really hot? would i need a custom heat shield there?
Old Jan 20, 2011 | 04:12 PM
Nizmo0395's Avatar
Nizmo0395
Sounds like you have it fixed wouldn't worry about it! Since your up north and
its winter time consider it an alternative heat source. Kidding, don't worry about it.
sales@czp
Sep 23, 2019 03:30 PM
issyz
Jul 2, 2017 03:04 PM
codek
Sep 28, 2015 03:03 AM
