OEM Y-pipe heat sheild - Can i remove it?
Old Jul 16, 2011 | 05:22 AM
ericjackson's Avatar
ericjackson
Default OEM Y-pipe heat sheild - Can i remove it?
so my heat shield is cracking all to hell. It is on my list to replace all of it. but right now im working on suspension and race wheels/hoosiers for autox. so just the test pipes will have to do for now.
Can i remove the heat shield? it rattles really loud and i am sick of putting new bolts in it to hold it together. Below are pics
Old Jul 16, 2011 | 06:00 AM
gidiup's Avatar
gidiup
Yep. Just careful if you do a serious drop on the car.
Mine did the same thing and removed it before getting new y pipe.
Old Jul 16, 2011 | 06:03 AM
ericjackson
Cool thanks. I wont be going any lower than I currently am for a while.
Old Jul 16, 2011 | 06:35 AM
ericjackson
Ok. Removed to find it holding together this.
Old Jul 16, 2011 | 06:38 AM
Itzcashew's Avatar
Itzcashew
IS it like that or did it break off? Yay time for a XYZ
Old Jul 16, 2011 | 06:51 AM
Yes. Not sure why Nissan engineers put things like heat shields under the car. Maybe sometime to do with shielding the undercarriage from heat or something silly.
Old Jul 16, 2011 | 07:18 AM
ericjackson
i am assuming it broke off. although its a clean break... im going to see a guy about welding it up at a muffler shop. Hoping to bandage it for now. because i need $600 next month for enkie rpf1's with hoosier a6's for our next autocross. then new endlinks
Old Jul 17, 2011 | 05:11 AM
gidiup's Avatar
gidiup
When I took mine off it didn't look like your picture. It just covered the connected pipe.
Looks broken off. Did you have an exhaust leak?
Shields aren't band-aids. They are meant to cover sealed exhaust systems.
Old Jul 17, 2011 | 05:40 AM
ericjackson
Yeah it was def a bad leak. And I already miss it. Getting this fixed totally killed my z's sound. When I installed test pipes last year is when it must have happened. It literally went from stock to loud and mean as ****. No one around has test pipes with oem exhaust so I thought it was how it was supposed to be. It was loud as **** and my wife hated it, but I got a lot if complements on it too.... I fixed this yesterday, and it sounds like I have my stock z back with no test pipes.
Old Jul 17, 2011 | 05:47 AM
ericjackson
this was it last weekend, i do not have a clip of it now, but i would say the sound reduced about 90-95%.
http://vimeo.com/26203584
Old Jul 17, 2011 | 06:44 AM
gidiup's Avatar
gidiup
Yeah... You can hear the leak in the video. I can hear the test pipes too.
Sorry dude.. You should at least hear the test pipes still. They are the ziggy noise.
Better safe than sorry with the exhaust leak. That stuff comes in the car plus your car should have a little better throttle response.
Sometimes too you can just pick up a used HR pipe and get a little better sound.
Old Jul 17, 2011 | 07:01 AM
Itzcashew's Avatar
Itzcashew
Y pipe are cheap used.
Old Jul 17, 2011 | 07:08 AM
ericjackson
The exhaust I want is the motordyne. Doesn't it come with its own ypipe? But not right now. I just miss the loud now. But it does sound much better and more smooth now. I just could not believe I have ridden around like that for a year.
Old Jul 17, 2011 | 07:58 AM
gidiup's Avatar
gidiup
There are a lot of systems with the Y included. I don't know if the motordyne is one of them.
I ran a HR Y and $600 Invidia system back. Was loud super dead and loud. No droning.
Youtube muffler systems on the 350 and see what sound you like best.
Old Jul 17, 2011 | 08:01 AM
ericjackson
Done this plenty. I can't make up my mind. Hah.
Old Jul 17, 2011 | 08:20 AM
gidiup's Avatar
gidiup
My only suggestion would be stay away from the drone sounding systems. Heard plenty of those in person and imo it just cheapens the Z. If you want that drive a honda.
The invidia N1, top speed, and HKS had the best deep sounding exhausts I've heard in person. I've heard dozens of set ups.
Money not an issue and with your pipes, HKS all day. Money an issue and you can find one, top speed. Top Speed N1 system is loud, loud.
Just remember... The pipes are going to add a little something.
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
350z82
Oct 1, 2015 06:25 PM
Depravity
Oct 1, 2015 04:49 PM
