Cat Bolts
Old Oct 18, 2011 | 06:54 AM
brandon7219's Avatar
brandon7219
Default Cat Bolts
So my cat bolts are seized on like no other. ive done soaks in pb and the like to no avail. ive been told try heating them up with a torch and my question to you is would a be a torch like this?
http://www.sears.com/shc/s/p_10153_1...=1318895039091
Old Oct 18, 2011 | 06:57 AM
Pengu's Avatar
Pengu
I believe so, have you tried using an impact gun though? That's how I was able to remove mine before needing a torch.
Old Oct 18, 2011 | 07:05 AM
brandon7219
no i havent. but im thinkin for 36$ thats a deal. instead of the gun $75 and upwards of 250$ and getting air pump for it, the torch is the way to go.
Old Oct 18, 2011 | 07:48 AM
JERZ350's Avatar
JERZ350
Did you try the breaker bar with a hammer in combination with what u mentioned? Essentially what an impact gun does. The sudden burst usually breaks it free rather than just trying to torque it off by hand. Just make sure your angle and force applied is even, so you dont strip or snap anything lol.
Old Oct 18, 2011 | 08:53 AM
viceversa's Avatar
viceversa
cut em off!
Old Oct 18, 2011 | 03:48 PM
brandon7219
well i tried the torch way to no avail today. ill give it another couple goes this week. but im thinking now when i get my exhaust the shop i go to maybe ill ask em if they can break the torque on the bolts header side and do the install when i get home. idk
Old Oct 18, 2011 | 05:08 PM
Bmurray350z's Avatar
Bmurray350z
My friend needed his taken off today. Took a torch to it with no problem at all.
Old Oct 18, 2011 | 05:25 PM
brandon7219
what kind of torch, like the one i posted?
Old Oct 18, 2011 | 08:08 PM
DaveJackson's Avatar
DaveJackson
Master
A torch like that should work. Do you know how to use one? Do you know where the hottest part of the flame is? Try about 30 seconds around the area.
Old Oct 18, 2011 | 11:15 PM
terrasmak's Avatar
A quality 6 point socket is a must before attempting to remove them.
Old Oct 19, 2011 | 05:21 AM
brandon7219
ive always thought the hottest part of a flame would be the blue steady flame? parts of the bolt were getting red hot for a second. im gonna give it another go today. yesterday was only about 40 degrees outside so maybe that was the problem.
Old Oct 19, 2011 | 05:30 AM
350zion's Avatar
350zion
Professional
Jus heat up the nut, that propane torch isn't gonna cut it like an oxy/ acetylene cutting torch will.. Instead ur going to heat up the steel n make it expand... Should turn out after that....
Good luck!
Old Oct 19, 2011 | 08:02 AM
brandon7219
Good luck!
yeah i knew it wouldn't cut it. ill give it a shot today if i gets above 38degrees like it is now x.x
Old Oct 19, 2011 | 01:05 PM
DaveJackson
Master
Also +1 as this is an excellent point.
Old Oct 20, 2011 | 01:30 AM
hpka365's Avatar
hpka365
I had the same issue with the bolts on my exhaust. Tried absolutely everything with almost every kind of tool you can think of. After wasting an entire day trying to get them off I gave up. Just bring it anywhere with a lift,give someone some cash on the side and ask them to cut the bolts off.
AbrasiveRaysive
Sep 20, 2021 02:29 PM
Li1ag
Sep 28, 2015 02:07 PM
