87mmFT Throttle Body Anyone?
Old May 10, 2013 | 07:34 PM
  #181
bikinilust's Avatar
bikinilust
JuicinJake can u please post pix of your setup
Very interested in doing
Old Jun 4, 2013 | 05:15 AM
  #182
wird06's Avatar
wird06
Anything new one this?
Old Jun 5, 2013 | 02:46 PM
  #183
mw9's Avatar
mw9
not really do to us both working around 70 hours a week no time for fun things right now
Old Jun 5, 2013 | 04:08 PM
  #184
Fixxxercask's Avatar
Fixxxercask
mw9, I think this is the other 87mm thread....I almost posted in it too...lol The title is almost the same.
Old Sep 28, 2013 | 07:40 PM
  #185
cbrg35's Avatar
cbrg35
Originally Posted by Z1 Performance
Can be useful if you have an intake manifold with an 87mm throat (or larger) and an intake tube with roughly an 87mm diamter. If neither of those things are present, it's going to largely be a giant waste of time unfortunately
do you know the bore on the kinetix V+ upper plenum? I have that and am looking at a throttle body spacer or that new nwp 75mm throttle body. thinking the TB will yield better results just looking for pro advice.
Old Sep 30, 2013 | 11:16 AM
  #186
str8dum1's Avatar
str8dum1
neither one is worth the money nor show any gains in the real world
Old Jun 2, 2017 | 02:57 PM
  #187
bealljk's Avatar
bealljk
subscribed
Old Jun 25, 2018 | 12:35 AM
  #188
milenkogt's Avatar
milenkogt
The titan guys who used the LS3/LS7 90mm throttle bodies with Uprev had to disable codes P2135 (TPS circuit range/performance) and P2119 (ETC actuator range/performance) in order for the engine to start up and run. If these aren't disabled, the RPM will hang and you won't have throttle input. Essentially going into limp mode.
The rest was just some adapter plates being made, or adapting a LS2 90mm snout and grafting it to the factory titan manifold.
The wiring harness was easy, you can buy OEM LS3 TB harness pigtails, match the pinouts and go from there.
Been using an LS3 gold blade 90mm DBW throttle body on my Titan since 2013.
OEM GM LS3 90mm Throttle body to use is Part # 12605109
I imagine the 87mm throttle bodies would work just as well and better suited for space constraints.
Old Nov 18, 2020 | 09:40 PM
  #189
Johnny Chen's Avatar
Johnny Chen
How to Buy the 80mm Throttle Body VQ35DE? Thanks.
Justin100
Nov 25, 2021 06:26 AM
