87mmFT Throttle Body Anyone?
Old Oct 23, 2012 | 03:18 PM
  #141
denchan350gt's Avatar
denchan350gt
Originally Posted by 2bad240
i ordered pnp harness from surratt and im gonna try the 75mm max tb on my car and i ordered piping and parts needed to make a complete 4" intake tube. will post results hoping to have on dyno on the 3rd
Are you still coming up for I vs D that weekend?
Old Oct 23, 2012 | 03:23 PM
  #142
2bad240's Avatar
2bad240
nah not gonna make it. some stuff came up so I used that money to order these parts
Old Nov 7, 2012 | 08:00 PM
  #143
denchan350gt
Here are a couple of pics of the stock 350z/g35 TB compared to a 09 Maxima TB.
left is stock
next to my P&P stock TB
to make it work and avoid soldering wires you will need this PNP harness made by surratt
I also had a adapter plate made for it to bolt up to the plenum. I'll post pics when I get it installed.
Old Nov 7, 2012 | 10:51 PM
  #144
npr350z's Avatar
npr350z
hmmm how much is the kit for the adapter plate and the harness going for? i know this is more of a pm talk but i figure a round about would help...would it come with the maxima tb or would be have to hunt one down our selves?
also anyone sending of their tb to be ported i recomend cordova motorsports. ive had nothing but good results with them, they can do most makes and models you just have to email them for pricing
Old Nov 8, 2012 | 01:15 PM
  #145
terrasmak's Avatar
I am really interested in doing this.
Old Nov 8, 2012 | 01:23 PM
  #146
2bad240's Avatar
2bad240
I got my max tb off eBay for $176 shipped. I'm taking the car to get tuned sat. so ill post results
oh and I had to cut those coolant pipes off mine for it to fit.
Old Nov 8, 2012 | 02:00 PM
  #147
CLyons0203's Avatar
CLyons0203
what is your intake setup? larger maf? airbox?
Old Nov 8, 2012 | 02:57 PM
  #148
2bad240's Avatar
2bad240
75mm tb and 4" intake
Old Nov 8, 2012 | 03:04 PM
  #149
Vq.turbo.DremZ's Avatar
Vq.turbo.DremZ
that looks dope....
Old Nov 8, 2012 | 05:58 PM
  #150
terrasmak's Avatar
And 180 degree AIT
Old Nov 9, 2012 | 01:26 AM
  #151
denchan350gt
Yeah I'm cutting off those lines also. TB I got for $164 shipped on eBay, harness for $100 from member surratt.
Adapter made by a maxima guy
I will be using 3in MAF housing, 3in Samco tube, PC filter with Stillen CAB modified to take in air from the lower grill also.
Track testing next Saturday.
2bad240 did you port match your plenum neck to the TB?
Old Nov 9, 2012 | 01:44 AM
  #152
2bad240's Avatar
2bad240
yea I actually opened it up in the bend of the neck too.
Old Nov 9, 2012 | 09:57 AM
  #153
SurraTT's Avatar
SurraTT
Here is my 5.7 gen maxima w 3.5" vs a 4" intake pipe.
As you can see soon as i put the 4" on it made power EVERYWHERE!
this is on a stock internal 2009 Maxima VQ35
Old Nov 10, 2012 | 05:11 PM
  #154
CLyons0203's Avatar
CLyons0203
I am guessing the Max TB outer diameter is about 3.25 inches. Did you use a reducer coupling to make the 4" intake fit? Does the intake have a velocity stack on it? When you installed this intake, did you get the car tuned? Was it driveable, seems like the motor would run really due without recalibrating the maf voltage in the ECU.
Old Nov 13, 2012 | 08:55 AM
  #155
AndyBGAWTSuhZ's Avatar
AndyBGAWTSuhZ
In for results! Awesome stuff right here guys. Currently running the PC with 3in MAF and 3in Samco intake tube similar to denchan350gt. 2bad240's setup is plain sick
Old Nov 13, 2012 | 09:01 AM
  #156
SurraTT's Avatar
SurraTT
Here is my setup, 4" intake with 09 max 75mm tb.
4" intake looks insane in person !
Old Nov 13, 2012 | 09:58 AM
  #157
AndyBGAWTSuhZ
@SurraTT
EDIT: What filter/stack are you using and where did you get the intake tube from/fabbed/whatever?? So 3in/75mm intake tube with 4in velocity stack filter?
Has anyone done any testing on a progressive intake tube? IE: 4in opening from filter (Can probably fit a 5-6in velocity stack w/ filter) progressively coupled down to a 3in at the maxima throttle body?
Old Nov 13, 2012 | 10:29 AM
  #158
juicinjake's Avatar
juicinjake
derek i know you know this, but this post is more for the rest. i have the exact same setup as derek in terms of the adapter plate, harness and throttle body. i made my own 3.5" intake fed from a modified 350z airbox/5" ram air. guys, in reference to the coolant lines... you can put the coolant line in a vise and rotate the tb so it clears the lower plenum. you dont have to cut them off. derek - props on the documentation and determination! looking forward to your results! ill post my reviews when i get the intake tube back from thermal coating...
Old Nov 13, 2012 | 10:37 AM
  #159
terrasmak's Avatar
I figure that im doing an 80mm tube, mounting the MAF sensor in the tube about 4 inches back from its factory location. The fit the filter, open up my JWT pop charger adapter to 80mm and have it welded to the intake tube for a velocity stack.
I may think about upping the piping to 90mm.
Old Nov 22, 2012 | 11:39 PM
  #160
harmysZ's Avatar
harmysZ
Has anyone ported out there throttle body inlet on the intake to see if it will make more power then an adaptor plate?or is there even enough material too do it?
