help with kinetix v+ stall
Old Apr 14, 2012 | 12:14 PM
350zeed's Avatar
350zeed
Default help with kinetix v+ stall
As soon as turn the key over, the car starts then stalls. When I turn the key and hit the gas, it idled fine. Any suggestions?
Old Apr 14, 2012 | 02:41 PM
JERZ350's Avatar
JERZ350
Check for pinching of any vacuum lines, make sure there are no leaks. Pray you didn't damage the MAF or Throttle Body during installation
Old Apr 14, 2012 | 03:04 PM
350zeed's Avatar
350zeed
Well, the maf never came off the Cai, it sounds as if it isn't getting fuel on start up. We can't find a air leak anywhere we used brake cleaner to test for leaks all around the gasket.
Old Apr 14, 2012 | 03:17 PM
supraturboman's Avatar
supraturboman
Try doing the idle re-learn procedure.
Old Apr 14, 2012 | 03:25 PM
350zeed's Avatar
350zeed
How do you do that ^
Old Apr 14, 2012 | 03:33 PM
2bad240's Avatar
2bad240
Did u block off the 6 holes in the lower Plenum where the factory one bolted down.
Old Apr 14, 2012 | 03:46 PM
350zeed's Avatar
350zeed
Yeah, that is bolted down.
Old Apr 14, 2012 | 06:47 PM
350zeed's Avatar
350zeed
Tried to do the re learn, that didn't work, any other takers?
Old Apr 15, 2012 | 02:07 AM
R350Zz33's Avatar
R350Zz33
make sure when testing for leaks the spray ur using has the type of gas that will raise the idle some dont anymore do to laws and ****
Old Apr 15, 2012 | 01:05 PM
350zeed's Avatar
350zeed
We sprayed carb cleaner around it last night and still no change to idle.
Old Apr 15, 2012 | 01:37 PM
supraturboman
Make sure the throttle body connector is pluged in.. Are you getting and trouble codes?
Old Apr 15, 2012 | 02:00 PM
AshMan's Avatar
AshMan
Club Moderator
the Hot Spot
When I installed mine, I took it to the dealership. They used their handheld computer to relearn the idle. Not sure what the difference is, but it worked like a champ.
Old Apr 15, 2012 | 02:47 PM
350zeed's Avatar
350zeed
**Update**
On start up with the engine cold, it starts up and runs fine. But once warmed up, once again start up is stalling shortly after start up.
I guess I will go to the dealership and have them hook up a computer.
Old Apr 16, 2012 | 02:42 AM
terrasmak's Avatar
**Update**
Mine has been doing that for years, it actually started doing that when i installed my Popcharger. Quick bump of the throttle after start, and all good.
Old Apr 16, 2012 | 01:59 PM
F2CMaDMaXX's Avatar
F2CMaDMaXX
Sounds like one of three things.
1) You need to successfully complete a throttle position re-learn.
2) Follow that with a successful idle air learn
3) Do you have an aftermarket intake or TB problem?
Old Apr 16, 2012 | 02:39 PM
installation's Avatar
installation
Its a leak, see my thread. I had the exact same problem. I bitched and argued that it wasn't a vacuum leak. I took it off, rebolted it all down to torque and used blue thread locker, did iavc relearn and unplugged battery overnight and its been perfect since.
Old Apr 16, 2012 | 04:59 PM
350zeed's Avatar
350zeed
1)done
2)done
3)full Cai
I took it off 3 times, but didn't use thread lock, where is your thread at?
Kyle1488
Oct 11, 2013 11:11 PM
jmcmorante
Jun 4, 2005 11:53 AM
go-g35
Nitrous Oxide
Jun 15, 2004 01:27 PM
alphared
Apr 8, 2004 12:34 PM
